Need help with TLC5947
Re: Need help with TLC5947
by Tchouala on Mon Jan 28, 2019 11:06 am
Hi once more pleasr can you give me a solution?
i realy need help
Tchouala
by adafruit_support_bill on Mon Jan 28, 2019 11:37 am
We have twice requested that you post a photo of your repaired solder joints. We cannot assist you if you do not follow instructions.
by franklin97355 on Mon Jan 28, 2019 12:19 pm
I'm sorry but I don't understand what you are doing. You need to solder headers on the board to use.
franklin97355
by Tchouala on Mon Jan 28, 2019 5:48 pm
here are the photos
Tchouala
by Tchouala on Mon Jan 28, 2019 6:13 pm
i just want to make it work like in the exple here: https://learn.adafruit.com/tlc5947-tlc5 ... t/overview
i have use the libary and code given in the link.
#include "Adafruit_TLC5947.h"
# include "SPI.h"
// How many boards do you have chained?
#define NUM_TLC5974 1
#define data   4
#define clock   5
#define latch   6
#define oe  4  // set to -1 to not use the enable pin (its optional)
Adafruit_TLC5947 tlc = Adafruit_TLC5947(NUM_TLC5974, clock, data, latch);
  Serial.begin(9600);
//   Set up the SPI
  SPI.setBitOrder(MSBFIRST);//Most Significant Bit First
  SPI.setDataMode(SPI_MODE0);// Mode 0 Rising edge of data, keep clock low
  SPI.setClockDivider(SPI_CLOCK_DIV4);//Run the data in at 16MHz/4 - 4MHz
  Serial.println("TLC5974 test");
  tlc.begin();
  if (oe >= 1) {
    pinMode(oe, OUTPUT);
    digitalWrite(oe, HIGH);
void loop() { colorWipe(4095, 0, 0, 100); // "Red" (depending on your LED wiring)
  delay(200);
  colorWipe(0, 4095, 0, 100); // "Green" (depending on your LED wiring)
  delay(200);
  colorWipe(0, 0, 4095, 100); // "Blue" (depending on your LED wiring)
  delay(200);
  rainbowCycle(10);
// Fill the dots one after the other with a color. j ai retirer wait
void colorWipe(uint16_t r, uint16_t g, uint16_t b, uint8_t wait) {
  for(uint16_t i=0; i<8*NUM_TLC5974; i++) {
      tlc.setLED(i, r, g, b);
      tlc.write();
      delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint32_t i, j;
  for(j=0; j<4096; j++) { // 1 cycle of all colors on wheel
    for(i=0; i< 8*NUM_TLC5974; i++) {
      Wheel(i, ((i * 4096 / (8*NUM_TLC5974)) + j) & 4095);
    tlc.write();
    delay(wait);
// Input a value 0 to 4095 to get a color value.
// The colours are a transition r - g - b - back to r.
void Wheel(uint8_t ledn, uint16_t WheelPos) {
  if(WheelPos < 1365) {
    tlc.setLED(ledn, 3*WheelPos, 4095 - 3*WheelPos, 0);
  } else if(WheelPos < 2731) {
    WheelPos -= 1365;
    tlc.setLED(ledn, 4095 - 3*WheelPos, 0, 3*WheelPos);
  } else {
    WheelPos -= 2731;
    tlc.setLED(ledn, 0, 3*WheelPos, 4095 - 3*WheelPos);
wenn i connect every cabel like said in the link LED dosent go on .
so i need your help to know what the problem ist.
Tchouala
by franklin97355 on Mon Jan 28, 2019 6:25 pm
You can't put your jumpers in like this. You are shorting the jumpers together. Connect them to the soldered pins at the other end.
franklin97355
by Tchouala on Mon Jan 28, 2019 7:38 pm
pictures of the soldering
Tchouala
by Tchouala on Mon Jan 28, 2019 8:09 pm
Hi ,i did so but no change .
one side ist output the oder one ist input .
i have to connect the jumpers on the input side .
in other to avoid problems with jumpers i also solder the other side .
these are the pictures
Tchouala
by Tchouala on Tue Jan 29, 2019 1:07 am
Hi , can you please help me ?
Tchouala
