Prototype is done - now what?
Get help, and assist others in with open source kits and running a business! Do not ask for legal advice or for consulting services in this forum, only general biz questions!
by mmathur on Wed Jul 27, 2011 2:30 pm
After my prototype is done and I've refined my code, how do I get my prototype into an assembled board with all the components soldered on as a finished prototype for an end product? Where would one start and which companies/vendors would be recommended to work with? Thanks.
mmathur
Re: Prototype is done - now what?
by adafruit on Wed Jul 27, 2011 2:57 pm
mmathur wrote:After my prototype is done and I've refined my code, how do I get my prototype into an assembled board with all the components soldered on as a finished prototype for an end product? Where would one start and which companies/vendors would be recommended to work with? Thanks.
if it's open source hardware, drop us a note - support@adafruit.com !
cheers,
by mmathur on Fri Jul 29, 2011 4:18 pm
That sounds like a plan. I'll be in touch...
mmathur
by ryochiji on Fri Sep 09, 2011 3:13 pm
Adafruit - Do you provide a secret assembly service for Open Source boards?
In any case, hopefully Adafruit will help you out, but here are some things I've learned about cheaply assembling prototype boards:
Prototype PCB printing:
Dorkbot PDX's PCB service is both cheap, reasonably fast, and high quality.
http://dorkbotpdx.org/wiki/pcb_order
Of course, there's also http://batchpcb.com, which costs a little more, but is pretty good (and has DRC + a visual way to check your gerber files).
I also used SeeedStudio's PCB service which is really cheap, if you don't mind waiting 2-4 weeks in shipping (from China). If you pay for faster shipping, it ends up being not-so-cheap, and still takes about as long as BatchPCB.
Prototype Assembly:
Professional assembly services are super expensive (generally at least $200, even for 1 board). Of the vendors I talked to, Advanced Circuits (http://4pcb.com) was the cheapest.
However, the cheapest solution is to do it yourself by hand. All you need is a good iron, flux, solder wick, faith, and determination. I'm a n00b, but was able to hand-solder MSOP chips and 0603 components with zero problems (well, except for the bug in the actual circuit design *sigh*). There are some good resources online for soldering SMD components (like this Sparkfun tutorial).
Anyway, hope this information helps someone.
email: ryo@bootstrapsolar.com
http://BootstrapSolar.com
ryochiji
by imaginerobots on Mon Sep 12, 2011 11:05 am
Seeedstudio also has a manufacturing service called Propagate:
http://www.seeedstudio.com/propagate/
I haven't used this yet.
Danh
imaginerobots
