mod kits for x0xb0x, TB-303 or ML303
Trading post for x0xen, x0x parts, axles, pelts and tobacco
isak
Re: mod kits for x0xb0x, TB-303 or ML303
Post by isak »
ok.
i'll look for it. thanks again :)
mwenzel
Post by mwenzel »
I have two questions : 1) Is the delay mod also applicable for the ACID Code ML 303 v4 ?
2) Do you still have the 2 VCO kit, so I could order it and mod my ML 303.
Thank you!
Marcus
substyler
Post by substyler »
hi Marcus,
as I'm not longer the owner of x0xsh0p you should ask Andreas from x0xsh0p.
just drop him a mail.
cheers,
Sub
ps. the delay mod is applicable for your Acidcode machine and the 2VCO mod too.
aminoacid
Post by aminoacid »
Hi Chris.
I just found a delay kit from you that i never installed in a xox a while ago.
I thought of putting it together now, but in a separate pedal box kind of thing and use it on sends with my mixer..
That shouldnt be any problem right?
Thoose pt chips are cool.
Is it possible to extend the delay time range?
Hope you are doing fine!
aminoacid
Post by aminoacid »
I bought A blue transparent box yesterday and assembled the effect.
I hooked one side of the switch to one pin of level pot, this way i can switch between dry/wet and just wet.
How ever, the signal could prob be stronger and the hi-end is very rolled of. Is there a lp filter in the circuit?
Return to “x0x shop”
