Still looking for backordered parts
Trading post for x0xen, x0x parts, axles, pelts and tobacco
computer controlled
Post by computer controlled »
Still looking for the 50k Linear pot, and it seems more items are back ordered...
100v .033uF Poly Film Caps - Part #140-PM2A333K
100v .0068uF Poly Film Caps - Part #140-PF2A682K
1/4" Phone Jacks - Part #568-NYS216
Anyone have extras for sale? I just ordered all the parts from Mouser, but these damn back ordered parts!
Also need these Digikey parts...
ENCODER 2 BIT QUAD SPST W/DETENT CT3011
ENCODER MECHANICAL 16POS HEX GH3074
POT 50K OHM 9MM VERT PLA BUSHING P3L2503
crazy owen
Post by crazy owen »
yeah pain in the butt right?!?!
my MB808 order was shipped in 6 or 7 different segments just because of backordered parts and I still had to order up some missign parts once I did a final inventory, wtf.
good luck.
loydmilligan
Post by loydmilligan »
You should be able to get the caps at digikey.
The jacks are a tough one, I bought four mono jacks and tore one apart to make one of the others stereo. The only jack that uses stereo is the headphone one. the part number for the mono jack is
nys2162.
for the quad encoder use part ct3007. You can shave it down to size with a dremel.
the hex encoder can be bought at newark and there is an alternative for the 50k pot on the BOM.
computer controlled
OK, so i've managed to source everything from that list, except for the 50k Lin Right Angle pot.
RV112BCF-40-25F-B54
This i just can't seem to find.
loydmilligan
both of the following pots will work without any problems (i have used both)
317-2200f-50k
317-2201f-50k
They have the exact same footprint but different dimensions on the top. The difference is not important as the only visible part of the pot is the shaft, which is identical just a different length. If the length is important you can shorten with a knife or dremel.
computer controlled
Cool, thanks for the info!
alex_dubinsky
Post by alex_dubinsky »
The replacement 1/4" jack is the
568-NYS215
It's stereo, just has a different nut. Actually I think it looks much better.
What I can't find is the encoder for the tempo knob. Anyone know a replacement?
EDIT: oh, i see someone found it. Whoa, I'm supposed to cut off the metal? I guess my dremmel could do that.... any tips to be safe?
computer controlled
Well, i just ordered everything i need, EXCEPT from last night to tonight, Digikey managed to run out of the 23 tact switches needed. With a lead time of 11/30. BANNED! Anyone know where i can get these? Or have a set for sale?
computer controlled
OK, so i found some, but i had to order 4 sets to meet the $35 minimum requirement. So if anyone needs a set of these, i'll have 3 extra sets!
Return to “x0x shop”
