Ferrite Bead
Ferrite Bead
by riscphree on Tue Jul 15, 2008 5:03 pm
I am looking to get a ferrite bead for this project, but I was wondering what rating I should be getting?
I haven't used ferrite beads before, but I do understand what they do. My journey though Mouser shows a ton of results, just slightly confused.
riscphree
by adafruit on Thu Jul 17, 2008 3:38 pm
the part num for the ferrite bead is here
http://svn.deepdarc.com/code/ybox2/trun ... 2parts.pdf
i think we just went with the cheapest one that was thru hole :)
by koolkat on Thu Jul 17, 2008 5:18 pm
ladyada wrote:i think we just went with the cheapest one that was thru hole :)
thats the only way to make it affordable....unless its "made in china" :)
koolkat
by darco on Sun Jul 20, 2008 3:36 pm
You can skip the ferrite bead if you want. It is primarily there to reduce EMI. I have built two or three ybox2's without ferrite beads and they work fine.
EDIT: I just realized that the advice I just gave was somewhat incorrect. If you don't have a ferrite bead, then use a simple wire instead. Otherwise the ethernet won't work.
darco
