using 0's in settings.setData
Talk about YBoxen, widgets, Propeller hacking, etc!
extremis
Post by extremis »
settings.setData(settings#NET_IPv4_MASK,string(255,255,255,0),4)
This is an example line from one of the example .spin files. The prop tool complains that strings must be from 1-255. How do I actually use a subnet mask of 255.255.255.0 if I can't put 0's in strings.
extremis
Re: using 0's in settings.setData
Post by extremis »
I answered my own question:
DAT
MAC            BYTE      $de, $ad, $be, $ef, $ca, $fe
IP             BYTE      10,0,1,2
MASK           BYTE      255, 255, 255, 0
GATEWAY        BYTE      10,0,1,1
DNS            BYTE      10,0,1,5
  settings.setData(settings#NET_IPv4_ADDR,@IP,4)
  settings.setData(settings#NET_IPv4_MASK,@MASK,4)
  settings.setData(settings#NET_IPv4_GATE,@GATEWAY,4)
  settings.setData(settings#NET_IPv4_DNS,@DNS,4)
darco
Post by darco »
Yeah, using the "string(...)" constant was a bit of a convenient hack for representing IP addresses in-line...at least as long as you don't have a zero in your IP address! Unfortunately, Parallax had the foresight of a myopic orangutan when they developed "spin", and decided that no one in the right mind would ever want to put a zero in an inline string constant.
Spin is the worst thing about the Propeller. The hardware is beautiful. The language is BANNED.
Return to “YBox2 (discontinued)”
