After building my ybox2 this weekend, I was a little disappointed when the info widget displayed html source, not formatted text.
I double-checked the instructions in the "Use It" pages, puttered around with the configuration settings, poked around this forum, and came across a post that said the server address has moved from 208.131.149.67 to 72.14.176.143. Making that change fixed the problem.
Assuming that this is a permanent change, I thought I should post to a) politely suggest that the info in the Use It section be updated to show the new address, b) suggest the infowidget binary in the Downloads section be updated to use the new address by default, c) add an item to the forum to give the new address greater visibility.
Other than that, I'm really delighted with the kit. It was a pleasure to build, a marvel to behold -- the Propeller, TV out and ethernet in a tin! -- and I look forward to using it to learn about Propeller programming.
Dan.
Info widget: server should be 72.14.176.143?
- gigamegawatts
Re: Info widget: server should be 72.14.176.143?
thanks for the suggestions, i've updated them!
ive copied infowidget to my server
you can now use
settings.setString(settings#SERVER_HOST,string("www.ladyada.net"))
settings.setData(settings#SERVER_IPv4_ADDR,string(207,58,139,246),4)
settings.setWord(settings#SERVER_IPv4_PORT,80)
settings.setString(settings#SERVER_PATH,string("/infowidget/?zipcode=95008"))
it shouldnt move, like, ever
thanks harrison!
you can now use
thanks harrison!
