I run
- Ubuntu 10.04
- Arduino 21
use
- Arduino Mega 1280
- Waveshield 1.1
I have sound when I push buttons - but it is distorted:
http://www.lo-bat.be/wendy/waveshield/Waveshield_slightly_distorted_sound.mp3
Not your usual distorted but a rrrrr (rolling r's - http://en.wikipedia.org/wiki/Alveolar_trill) sound extra
Here are a few of my original sounds - the ones which are on the SD-card of the wavsehield
http://www.lo-bat.be/wendy/waveshield/SOUND1.wav
http://www.lo-bat.be/wendy/waveshield/SOUND10.wav
http://www.lo-bat.be/wendy/waveshield/SOUND11.wav
http://www.lo-bat.be/wendy/waveshield/SOUND12.wav
http://www.lo-bat.be/wendy/waveshield/SOUND13.wav
http://www.lo-bat.be/wendy/waveshield/SOUND14.wav
Here is an image of the waveshield - with the modifications indicated here:
http://forums.adafruit.com/viewtopic.php?f=31&t=10939&start=45 -> instructions given by fat16lib
Photograph of the Waveshield & Mega
http://www.lo-bat.be/wendy/waveshield/mega_and_waveshield.JPG
(the copper thingy in the corner connects my buttons to the ground - and there is no current flowing between the pins 50-53 and the ground...)
My code for playing the 20 sound files:
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the filesystem on the card
FatReader f; // This holds the information for the file we're play
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
#define DEBOUNCE 5 // button debouncer
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41};
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'pressed' (the current state
volatile byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
void sdErrorCheck(void)
if (!card.errorCode()) return;
putstring("\n\rSD I/O error: ");
Serial.print(card.errorCode(), HEX);
putstring(", ");
Serial.println(card.errorData(), HEX);
while(1);
byte i;
// set up serial port
Serial.begin(9600);
putstring_nl("WaveHC with ");
Serial.print(NUMBUTTONS, DEC);
putstring_nl("buttons");
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(freeRam()); // if this is under 150 bytes it may spell trouble!
// Set the output pins for the DAC control. This pins are defined in the library
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
// pin13 LED
pinMode(13, OUTPUT);
// Make input & enable pull-up resistors on switch pins
for (i=0; i< NUMBUTTONS; i++) {
pinMode(buttons[i], INPUT);
digitalWrite(buttons[i], HIGH);
// if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
if (!card.init()) { //play with 8 MHz spi (default faster!)
putstring_nl("Card init. failed!"); // Something went wrong, lets print out why
sdErrorCheck();
while(1); // then 'halt' - do nothing!
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
putstring_nl("No valid FAT partition!");
sdErrorCheck(); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(),DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
putstring_nl("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Ready!");
TCCR2A = 0;
TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
//Timer2 Overflow Interrupt Enable
TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
check_switches();
void check_switches()
static byte previousstate[NUMBUTTONS];
static byte currentstate[NUMBUTTONS];
byte index;
for (index = 0; index < NUMBUTTONS; index++) {
currentstate[index] = digitalRead(buttons[index]); // read the button
Serial.print(index, DEC);
Serial.print(": cstate=");
Serial.print(currentstate[index], DEC);
Serial.print(", pstate=");
Serial.print(previousstate[index], DEC);
Serial.print(", press=");
if (currentstate[index] == previousstate[index]) {
if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
// just pressed
justpressed[index] = 1;
else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
// just released
justreleased[index] = 1;
pressed[index] = !currentstate[index]; // remember, digital HIGH means NOT pressed
//Serial.println(pressed[index], DEC);
previousstate[index] = currentstate[index]; // keep a running tally of the buttons
byte i;
if (justpressed[0]) {
justpressed[0] = 0;
playfile("SOUND1.WAV");
else if (justpressed[1]) {
justpressed[1] = 0;
playfile("SOUND2.WAV");
else if (justpressed[2]) {
justpressed[2] = 0;
playfile("SOUND3.WAV");
else if (justpressed[3]) {
justpressed[3] = 0;
playfile("SOUND4.WAV");
else if (justpressed[4]) {
justpressed[4] = 0;
playfile("SOUND5.WAV");
else if (justpressed[5]) {
justpressed[5] = 0;
playfile("SOUND6.WAV");
else if (justpressed[6]) {
justpressed[6] = 0;
playfile("SOUND7.WAV");
else if (justpressed[7]) {
justpressed[7] = 0;
playfile("SOUND8.WAV");
else if (justpressed[8]) {
justpressed[8] = 0;
playfile("SOUND9.WAV");
else if (justpressed[9]) {
justpressed[9] = 0;
playfile("SOUND10.WAV");
else if (justpressed[10]) {
justpressed[10] = 0;
playfile("SOUND11.WAV");
else if (justpressed[11]) {
justpressed[11] = 0;
playfile("SOUND12.WAV");
else if (justpressed[12]) {
justpressed[12] = 0;
playfile("SOUND13.WAV");
else if (justpressed[13]) {
justpressed[13] = 0;
playfile("SOUND14.WAV");
else if (justpressed[14]) {
justpressed[14] = 0;
playfile("SOUND15.WAV");
else if (justpressed[15]) {
justpressed[15] = 0;
playfile("SOUND16.WAV");
else if (justpressed[16]) {
justpressed[16] = 0;
playfile("SOUND17.WAV");
else if (justpressed[17]) {
justpressed[17] = 0;
playfile("SOUND18.WAV");
else if (justpressed[18]) {
justpressed[18] = 0;
playfile("SOUND19.WAV");
else if (justpressed[19]) {
justpressed[19] = 0;
playfile("SOUND20.WAV");
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
// call our helper to find and play this name
playfile(name);
while (wave.isplaying) {
// do nothing while its playing
// now its done playing
void playfile(char *name) {
// see if the wave object is currently doing something
if (wave.isplaying) {// already playing something, so stop it!
wave.stop(); // stop it
// look in the root directory and open the file
if (!f.open(root, name)) {
putstring("Couldn't open file "); Serial.print(name); return;
// OK read the file and turn it into a wave object
if (!wave.create(f)) {
putstring_nl("Not a valid WAV"); return;
// ok time to play! start playback
wave.play();
I have no idea why I have the distortion :-/
Any clues? Que pasa?
Bizarre: running the Daphc sketch (which plays all sounds it finds on the sd-card) gives me no distortion whatsoever.
