VS1053 - Trouble getting examples to work
Re: VS1053 - Trouble getting examples to work
by DracoCarathyr on Thu Nov 06, 2014 2:39 pm
The thing I am having trouble with is that I have the header file in the Library folder for the IDE, but I try to import it it just gives me a blank line. I opened one of the sketches it says there is not a header file for Adafruit_VS1053, even though it has
# include <Adafruit_VS1053.h>
. I followed the direction to import a library, too.
DracoCarathyr
by adafruit_support_mike on Fri Nov 07, 2014 2:27 am
You have a space between the '#' and the 'include'. You need to remove that.
'#include' is a single keyword.
by DracoCarathyr on Fri Nov 07, 2014 12:08 pm
The header file is in the directory, but when I compile or try to import the library it either says it is not in the directory or just creates a blank line
This is the error message:
Arduino: 1.5.8 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
player_simple.ino:17:29: fatal error: Adafruit_VS1053.h: No such file or directory
compilation terminated.
Error compiling.
enabled in File > Preferences.
vs1053 sketch problem.png (131.77 KiB) Viewed 879 times
DracoCarathyr
by adafruit_support_mike on Fri Nov 07, 2014 12:20 pm
Have you restarted the Arduino IDE since you put the Adafruit_VS1053 library in sketchkook/libraries?
The IDE only looks for headers at startup, so any libraries you add while it's running remain unseen, even though the files are where they're supposed to be.
Also make sure you've trimmed the '-master' off the name of the directory that contains the .h and .cpp files. The IDE will ignore any directory whose name contains anything other than letters, numbers, or underscores.
by DracoCarathyr on Fri Nov 07, 2014 12:31 pm
Apparently when I unzipped it there was an extra folder (the library was in a folder labeled "Adafruit_VS1053" which was in a folder of the same name) that I added to the library. It seems to work now. Funny that that was all it was.
DracoCarathyr
by adafruit_support_mike on Sat Nov 08, 2014 1:19 am
The Arduino IDE is kind of picky about things like that.
It isn't bad to work with once you've learned its quirks, but it does take a bit of getting used to.
Glad to hear you got it working. Happy hacking!
by DracoCarathyr on Sat Nov 08, 2014 2:20 pm
Thank you
DracoCarathyr
by lunes on Mon Dec 15, 2014 9:36 am
Does this breakout need 5V or can I power it with 3.3V?
lunes
by adafruit_support_bill on Mon Dec 15, 2014 9:40 am
The board will run on 3.3v also.
