arduino motor shield V2.3 - 3 DC motors and another I2C devi
prathapchandra
Post by prathapchandra »
I have an I2C based touchpad from which I am extracting button pressed information, and this controls my car rear view mirror.
the issue i am facing is, when my control enter switch statement, the system hangs, serial com hangs up, I2C bus remains high voltage.
below is the code:
#include <Wire.h>
#include <SPI.h>
#include <LocateZone.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_DCMotor *Motor1 = AFMS.getMotor(1);
Adafruit_DCMotor *Motor2 = AFMS.getMotor(2);
Adafruit_DCMotor *Motor3 = AFMS.getMotor(3);
#define DEV_Addr 0X3  //Device I2C address in Hex
const ZONE_T virtualZone[ VIRTUAL_ZONE_MAX ] = {
  POLYGON_PROCESS,              /* process type  */
  4,
  708, 1140,                  //up button
  1228, 1889,
  187, 1889,
  187, 1889,
  /* VZ2 defaults  */
  4,
  708,  907,                   //down button
  188,  158,
  1229,  158,
  1229,  158,
  /* VZ3 defaults  */
  4,
  789, 1023,                  //left button
  1310, 275,
  1310, 1772,
  1310, 1772,
  /* VZ4 defaults  */
  4,
  106,  1771,                 //right button
  305,  1023,
  106,  275,
  106,  275,
  /* VZ5 defaults  */
  4,
  1554, 157,                  //main up
  1926, 157,
  1554, 941,
  1926, 941,
  /* VZ6 defaults  */
  4,
  1555,  1106,                 //main down
  1927,  1106,
  1555,  1889,
  1927,  1889,
unsigned short combinedx = 0;                                                   //variables to hold combined values(MSB,LSB) of the X,Y and F
unsigned short combinedy = 0;
unsigned short combinedz = 0;
float  X_LOC, Y_LOC,F_FORCE;                                                    //Location(mm) and Force(N) values
byte mySensVals[6];                                                             //To store the read I2C buffer data
int Sensitivity = 100, zoneNumber=0;
int sensorValue1 = analogRead(A0);
int sensorValue2 = analogRead(A1);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 3.3V):
float m1pos;
float m2pos;
// print out the value you read:
void setup()
  Wire.begin();
  AFMS.begin(64000);  // create with the default frequency 64KHz
  Motor1->setSpeed(200);
  Motor1->run(RELEASE);
  Motor2->setSpeed(200);
  Motor2->run(RELEASE);
  Motor3->setSpeed(200);
  Motor3->run(RELEASE);
  zoneNumber = 0;
  #if 0
  TWBR = ((F_CPU / 400000l) - 16) / 2; // Change the i2c clock from 100KHz to 400KHz
  #endif
void loop()
         zoneNumber=0;
         ReadBuffer();
         GetValues();
         delay(500);
              for (int idx = 0; idx < 6; idx++)
                    if ( zoneNumber == 0 )  /* still no zone found ?  Then test the next VBZ  */
                                 if (IsPointInPolygon( idx ) == true)
                                    zoneNumber = idx + 1;
                    else
                    break;    /* exit the outer loop.  A zone has been found  */
         Serial.print("Zone Number : ");
         Serial.println(zoneNumber);
         A2DC();
                             switch (zoneNumber)
                                case 1:
                                     Motor2->run(FORWARD);            // turn on motor
                                     delay(1000);
                                     break;
                                case 2:
                                     Motor2->run(BACKWARD);            // turn on motor
                                     delay(1000);
                                     break;
                                case 3:
                                     Motor1->run(BACKWARD);            // turn on motor
                                     delay(1000);
                                     break;
                                case 4:
                                     Motor1->run(FORWARD);            // turn on motor
                                     delay(1000);
                                     break;
                                case 5:
                                     Motor3->run(FORWARD);            // turn on motor
                                     delay(1000);
                                     break;
                                case 6:
                                     Motor3->run(BACKWARD);            // turn on motor
                                     delay(1000);
                                     break;
// determine if point is in the triangle
* This function determines whether measured points are in a Polygon or not
* \param        VBZidx  index to the VBZ being considered
* \retval       BOOL            True if point lies in polygon
*                               False if it doesn't
static bool IsPointInPolygon( unsigned char VBZidx )
    unsigned char iIdx;
    unsigned char jIdx;
    unsigned char vertCount;
    bool tp_Presence = false;
    /* find the number of verticies in this poly less 1*/
    vertCount = (unsigned char)virtualZone[VBZidx].polyCount;
    /* preset the jIdx to the end of the array of verticies  */
    jIdx = vertCount - 1U;
    for (iIdx = 0; iIdx < vertCount; iIdx++ )
        if ((( virtualZone[VBZidx].vertex[iIdx].y <= combinedy ) &&
             ( virtualZone[VBZidx].vertex[jIdx].y >= combinedy )) ||
            (( virtualZone[VBZidx].vertex[jIdx].y <= combinedy ) &&
             ( virtualZone[VBZidx].vertex[iIdx].y >= combinedy )))
            if (( virtualZone[VBZidx].vertex[iIdx].x + (float)( combinedy - virtualZone[VBZidx].vertex[iIdx].y) / /* PRQA S 3395, 3390, 1800, 4393 */
                                    (float)(virtualZone[VBZidx].vertex[jIdx].y - virtualZone[VBZidx].vertex[iIdx].y) *    /*PRQA S 1800, 4393 */
                                    (virtualZone[VBZidx].vertex[jIdx].x - virtualZone[VBZidx].vertex[iIdx].x))  <=  combinedx)/* PRQA S 1802 */
                tp_Presence ^= true;  /* an odd count leaves this = TRUE */
            else { /* MISRA compliance  */}
        jIdx = iIdx;  /* move down the array of verticies */
    return (tp_Presence);
// Read the Data buffer from the POC over I2C
void ReadBuffer()  //Read the data buffer from the SwitchPack using i2c
   Wire.beginTransmission(DEV_Addr);     // transmit to device
   Wire.write(byte(0x10));               // contains data buffer
   Wire.write(byte(0x20));               // contains data buffer
   Wire.endTransmission();               // stop transmitting
   Wire.requestFrom(DEV_Addr, 6);    // request 6 bytes from slave device
   // receive reading from sensor
   while(Wire.available())          // slave may send less than requested
     int ind;
        for (ind =0; ind <= 6; ind++)
          mySensVals[ind] = Wire.read();
// Get the x, y, F values from the read buffer data
void GetValues()
   unsigned char xhi = mySensVals[0];     //Combine the MSB abd LSB data bytes to get the X value
   unsigned char xlo = mySensVals[1];
   combinedx = xhi;
   combinedx = combinedx<<8;
   combinedx |=xlo;
   Serial.println(combinedx);
   unsigned char yhi = mySensVals[2];     //Combine the MSB abd LSB data bytes to get the Y value
   unsigned char ylo = mySensVals[3];
   combinedy = yhi;
   combinedy = combinedy<<8;
   combinedy |=ylo;
   Serial.println(combinedy);
   unsigned char zhi = mySensVals[4];     //Combine the MSB abd LSB data bytes to get the Z value
   unsigned char zlo = mySensVals[5];
   combinedz = zhi;
   combinedz = combinedz<<8;
   combinedz |=zlo;
   Serial.println(combinedz);
//Read mirror Position
void A2DC()
  float voltage1 = sensorValue1 * (3.3 / 1023.0);
  float voltage2 = sensorValue2 * (3.3 / 1023.0);
  Serial.println(voltage1);
  Serial.println(voltage2);
  Serial.println();
clearly, there seems to be I2C bus contention.
any insights is deeply appreciated
thank you
Prathap
Re: arduino motor shield V2.3 - 3 DC motors and another I2C
Have you verified that the motor shield and your other device both function independently? I looks like your other device uses address 0x03. The Motor shield defaults to addresses 0x60 and 0x70. There is no way to address it to 0x03.
prathapchandra
yes, both function independently very well.
I was using Arduino Zero, while I reported this observation.
meanwhile, I tried with Leonardo and a UNO, the system doesn't hang with these two boards, however, the zone values have an error.
hence control is not as intended press
thanks for responding so quickly
thank you
Prathap
Try running the i2c scanner. That will show if all devices are responding normally on the bus.
https://playground.arduino.cc/Main/I2cScanner
prathapchandra
the I2C scanner is identifying three I2C devices and below is the message on the serial comm
Scanning...
I2C device found at address 0x03 !
I2C device found at address 0x60 !
I2C device found at address 0x70 !
done
How long is your i2c bus? The UNO is 5v, while the Zero is 3.3v. The Zero will be more sensitive to bus capacitance and noise.
prathapchandra
Am facing two issues as of now
1. With Arduino Zero + motor shield + I2C device - system hangs when I try to run the motors
2. With Arduino Uno or Leonardo +motor shield + I2C device - the system processes the zone information incorrectly.
I am welcome to suggestions to make this work, what I thought was a simple task is taking up a lot of time.
thank you
Prathap
prathapchandra
the wire length is about 15 inches approximately.
prathapchandra
I cut short the I2C SDA and SCL lines to about 8 inches approximately.
still the same issue
The Zero is going to be more sensitive to line capacitance and noise. 8" is generally not a problem. But motors are notorious sources of noise. Some details on the motors you are using and photos showing your wiring may be helpful.
Can you explain what you mean by that? It might help to post the zone processing code you are referring to.
prathapchandra
the issue is seen even without connecting the motors. there three motors though.
the code I posted in my first comment has the zone calculation function as well.
Your analog readings are assuming a 3.,3v voltage reference. The default on the UNO is 5v.
void A2DC()
  Serial.println();
prathapchandra
yes, please ignore that, those values are for limiting values, am not using them yet until I can get correct zone values and be able to control the motor as intended.
Then please post the relevant bit of code.
prathapchandra
found a fix for setup 1 - Zero + Motor Shield + I2C device
  This is a library for our Adafruit 16-channel PWM & Servo driver
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/815
  These displays use I2C to communicate, 2 pins are required to
  interface. For Arduino UNOs, thats SCL -> Analog 5, SDA -> Analog 4
  products from Adafruit!
#include <Adafruit_MS_PWMServoDriver.h>
#include <Wire.h>
 #define WIRE Wire
Adafruit_MS_PWMServoDriver::Adafruit_MS_PWMServoDriver(uint8_t addr) {
  _i2caddr = addr;
void Adafruit_MS_PWMServoDriver::begin(void) {
 WIRE.begin();
 reset();
void Adafruit_MS_PWMServoDriver::reset(void) {
 write8(PCA9685_MODE1, 0x0);
void Adafruit_MS_PWMServoDriver::setPWMFreq(float freq) {
  //Serial.print("Attempting to set freq ");
  //Serial.println(freq);
  freq *= 0.9;  // Correct for overshoot in the frequency setting (see issue #11).
  float prescaleval = 25000000;
  prescaleval /= 4096;
  prescaleval /= freq;
  prescaleval -= 1;
  //Serial.print("Estimated pre-scale: "); Serial.println(prescaleval);
  uint8_t prescale = floor(prescaleval + 0.5);
  //Serial.print("Final pre-scale: "); Serial.println(prescale);
  uint8_t oldmode = read8(PCA9685_MODE1);
  uint8_t newmode = (oldmode&0x7F) | 0x10; // sleep
  write8(PCA9685_MODE1, newmode); // go to sleep
  write8(PCA9685_PRESCALE, prescale); // set the prescaler
  write8(PCA9685_MODE1, oldmode);
  delay(5);
  write8(PCA9685_MODE1, oldmode | 0xa1);  //  This sets the MODE1 register to turn on auto increment.
                                          // This is why the beginTransmission below was not working.
  //  Serial.print("Mode now 0x"); Serial.println(read8(PCA9685_MODE1), HEX);
void Adafruit_MS_PWMServoDriver::setPWM(uint8_t num, uint16_t on, uint16_t off) {
  //Serial.print("Setting PWM "); Serial.print(num); Serial.print(": "); Serial.print(on); Serial.print("->"); Serial.println(off);
  WIRE.beginTransmission(_i2caddr);
  WIRE.write(byte(LED0_ON_L+4*num));
  WIRE.write(byte(on));
  WIRE.write(byte(on>>8));
  WIRE.write(byte(off));
  WIRE.write(byte(off>>8));
  WIRE.endTransmission();
uint8_t Adafruit_MS_PWMServoDriver::read8(uint8_t addr) {
  WIRE.write(byte(addr));
  WIRE.requestFrom((uint8_t)_i2caddr, (uint8_t)1);
  return WIRE.read();
void Adafruit_MS_PWMServoDriver::write8(uint8_t addr, uint8_t d) {
  WIRE.write(byte(d));
all wire.write values should be "byte"
do you know why this solved the issue?
thank you
Prathap
