Motor shield V2 issues--motor won't run despite arduino code
by Aub on Tue Dec 05, 2017 12:26 am
So the motor won't run when I activate the DC motor software test. I've made sure that:
The test code says it's uploading correctly, but nothing happens.
My power source is 4 AA batteries in series wired to the terminal on the board and the arduino board is USB powered.
I do have the DC brush motor connected to M1
The green LED is brightly lit.
Is there something I missed?
Aub
Re: Motor shield V2 issues--motor won't run despite arduino
by adafruit_support_bill on Tue Dec 05, 2017 7:01 am
We need a little more information to assist you. Please post:
* Photos showing your soldering and connections.
* Electrical specifications for your motor.
* The code you are using.
by Aub on Tue Dec 05, 2017 5:51 pm
Sorry for the late reply I was at school.
[img]https://i.imgur.com/NG9gIQu.jpg/img]
Yeah, I didn't solder them I used hot glue to keep the wires in place. Sorry I know that's not ideal, but I made sure all the wires/pins were in contact.
I am using the test code for DC motors.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
// You can also make another motor on port M2
//Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Adafruit Motorshield v2 - DC Motor test!");
  AFMS.begin();  // create with the default frequency 1.6KHz
  //AFMS.begin(1000);  // OR with a different frequency, say 1KHz
  // Set the speed to start, from 0 (off) to 255 (max speed)
  myMotor->setSpeed(150);
  myMotor->run(FORWARD);
  // turn on motor
  myMotor->run(RELEASE);
  uint8_t i;
  Serial.print("tick");
  for (i=0; i<255; i++) {
    myMotor->setSpeed(i);
    delay(10);
  for (i=255; i!=0; i--) {
    delay(10);
  Serial.print("tock");
  myMotor->run(BACKWARD);
    delay(10);
    delay(10);
  Serial.print("tech");
  delay(1000);
I'm a little lacking on electrical specifications for the motors since I snagged them from a pile from a class. I know that DC motors attended to run off 1.5V-3V don't work with the shield, but I normally run these motors off a 9V battery, so I don't think they're 1.5-3V. I do know that they are DC brush motors.
Aub
by adafruit_support_bill on Tue Dec 05, 2017 6:00 pm
It is more than 'not ideal'. It is pretty much guaranteed not to work. You need to solder those connections to assure reliable electrical contact.
by Aub on Wed Dec 06, 2017 10:56 pm
yeah surprise surprise, I soldered it and it works now... XD. Thanks.
Aub
by adafruit_support_bill on Thu Dec 07, 2017 7:07 am
Good to hear. Thanks for the follow-up.
