I have a Standalone AVR Chip Programmer thats been sitting in my parts box for some time and I want to use it to burn some bootloaders.
If I use it as specified in the ArduinoISP, it works, but I want it to be standalone.
When following the Standalone guide, if I try compiling the AdaLoader sketch in Arduino version 1.8.5 I get the following:
/root/Arduino/AdaLoader/AdaLoader.ino: In function 'void loop()':
/root/Arduino/AdaLoader/AdaLoader.ino:82:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("Signature fail");
/root/Arduino/AdaLoader/AdaLoader.ino:84:23: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("Image fail");
/root/Arduino/AdaLoader/AdaLoader.ino:89:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("Programming Fuses fail");
/root/Arduino/AdaLoader/AdaLoader.ino:92:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("Failed to verify fuses");
/root/Arduino/AdaLoader/AdaLoader.ino:113:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("Flash programming failed");
/root/Arduino/AdaLoader/AdaLoader.ino:121:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/root/Arduino/AdaLoader/AdaLoader.ino:128:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("Failed to verify chip");
/root/Arduino/AdaLoader/AdaLoader.ino:134:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/tmp/ccTbQny2.ltrans0.ltrans.o: In function `start_pmode()':
/root/Arduino/AdaLoader/AdaLoader.ino:170: undefined reference to `spi_transaction(unsigned char, unsigned char, unsigned char, unsigned char)'
/tmp/ccTbQny2.ltrans0.ltrans.o: In function `setup':
/root/Arduino/AdaLoader/AdaLoader.ino:51: undefined reference to `pulse(int, int)'
/root/Arduino/AdaLoader/AdaLoader.ino:53: undefined reference to `pulse(int, int)'
/tmp/ccTbQny2.ltrans0.ltrans.o: In function `loop':
/root/Arduino/AdaLoader/AdaLoader.ino:81: undefined reference to `readSignature()'
/root/Arduino/AdaLoader/AdaLoader.ino:83: undefined reference to `findImage(unsigned int)'
/root/Arduino/AdaLoader/AdaLoader.ino:86: undefined reference to `eraseChip()'
/root/Arduino/AdaLoader/AdaLoader.ino:88: undefined reference to `programFuses(unsigned char const*)'
/root/Arduino/AdaLoader/AdaLoader.ino:91: undefined reference to `verifyFuses(unsigned char const*, unsigned char const*)'
/root/Arduino/AdaLoader/AdaLoader.ino:105: undefined reference to `readImagePage(unsigned char*, unsigned int, unsigned char, unsigned char*)'
/root/Arduino/AdaLoader/AdaLoader.ino:112: undefined reference to `flashPage(unsigned char*, unsigned int, unsigned char)'
/root/Arduino/AdaLoader/AdaLoader.ino:120: undefined reference to `programFuses(unsigned char const*)'
/root/Arduino/AdaLoader/AdaLoader.ino:127: undefined reference to `verifyImage(unsigned char*)'
/root/Arduino/AdaLoader/AdaLoader.ino:133: undefined reference to `verifyFuses(unsigned char const*, unsigned char const*)'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Duemilanove or Diecimila.
If I try using Arduino 1.0 or Arduino 0023 I get the following message:
./arduino: 22: ./arduino: java: not found
