Winc1500 SD
jdelcamp11
Winc1500 SD
Post by jdelcamp11 »
I purchased the winc1500 shield
The board works perfectly on my genuino101.
But nothing is working on my DUE.
The SD reports failed to initialize
The check firmware works if I comment out the // Check for the presence of the shield if section
All other routines hang.
Is there a way to get this shield working on a DUE???
jdelcamp11
Re: Winc1500 SD
I have found a solution to the wifi problems:
Contrary to Adafruits tutorial, The default pin definitions DO NOT match the library definitions.
you have to define the pins
  /*These are the selectable interrupt and control pins for the Winc1500 */
#define wifi_IRQ    7  // MUST be an interrupt pin!
#define wifi_Reset  5  // These 2 can be any two pins
#define wifi_CS    10
  // Use hardware SPI for the remaining pins
  // On an UNO, SCK = 13, MISO = 12, and MOSI = 11 */
  WiFi.setPins(wifi_CS,wifi_IRQ,wifi_Reset);
I don't know yet if this solves the SD card issues, but now I can use the Wifi
jdelcamp11
Re: Winc1500 SD
found a solution to the SD problem.
I changed the SD library to the one from Adafruit.
https://github.com/adafruit/SD
All is well now.
