my screen of adafruit has broken, so I bough a new TFT 2.8'' LCD shield restative, but when I upload the program to my arduino, nothing happens. I don't know what the problem is, but I need the screen to show my gui of using the arduino. the example of code is:
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
#include <string.h>
#include <Wire.h>
// all of this in common.h
#define TFT_CS 10
#define TFT_DC 9
#define STMPE_CS 8
#define BUTTON_NUMBER_HEIGHT 45
#define BUTTON_NUMBER_WIDTH 45
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
#define DIALHEIGHT 50
#define DIALWIDTH 50
#define DIALY 300
#define DIALX 110
#define MESSAGEX 150
#define SIZE_TEXT_BUTTON 2
#define INCREAMENT 55
#define MAXLENGTHPHONENUMBER 11
#define DELETE_X 200
#define DELETE_Y 20
#define DELETE_HEIGHT 40
#define DELETE_WIDTH 40
#define PRINT_X_START 20
#define PRINT_Y_START 20
#define PRINT_HEIGHT 14
#define PRINT_WIDTH 140
#define FONT_SIZE_INPUT_PHONE 2
Adafruit_ILI9341 tft=Adafruit_ILI9341(TFT_CS,TFT_DC);
Adafruit_STMPE610 ts=Adafruit_STMPE610(STMPE_CS);
Adafruit_GFX_Button myButtons[12],eraseButton,dialButton,messageButton;
char* buttonsLabel[12]={"1","2","3","4","5","6","7","8","9","*","0","#"},phoneNumber[MAXLENGTHPHONENUMBER+1];
int x=60, y=80,starterx=x;
const int buttonsLength=sizeof(myButtons)/sizeof(myButtons[0]);
TS_Point lastPointChecked;
bool doUpdate,firstTime=true,hasCursor=false;
void buttonsInit()
eraseButton=Adafruit_GFX_Button();
dialButton=Adafruit_GFX_Button();
messageButton=Adafruit_GFX_Button();
for(int i=0;i<buttonsLength;i++)
myButtons[i]=Adafruit_GFX_Button();
if(i%3==0&&i!=0)
x=starterx;
y+=INCREAMENT;
myButtons[i].initButton(&tft,x,y,BUTTON_NUMBER_WIDTH,BUTTON_NUMBER_HEIGHT,ILI9341_ORANGE,ILI9341_BLUE,ILI9341_BLACK,buttonsLabel[i],SIZE_TEXT_BUTTON);
x+=INCREAMENT;
void beginAll()
tft.begin();
ts.begin();
tft.fillScreen(ILI9341_WHITE);
Serial.begin(9600);
while(!Serial);
phoneNumber[0]=0;
void drawNumbers()
if(firstTime)
myButtons[i].drawButton();
return;
if(ts.touched()==false)
doUpdate=false;
return;
doUpdate = true;
myButtons[i].drawButton(myButtons[i].isPressed());
void ChangeEditButtonsVisiblity(bool destVisible)
if(destVisible==true)
eraseButton.initButton(&tft,DELETE_X, DELETE_Y,DELETE_WIDTH,DELETE_HEIGHT,ILI9341_BLACK,ILI9341_BLACK,ILI9341_WHITE,"<--",SIZE_TEXT_BUTTON);
eraseButton.drawButton();
dialButton.initButton(&tft,DIALX,DIALY,DIALWIDTH,DIALHEIGHT, ILI9341_GREEN,ILI9341_GREEN, ILI9341_WHITE, "Dial",SIZE_TEXT_BUTTON);
dialButton.drawButton();
/*messageButton.initButton(&tft, MESSAGEX,DIALY,DIALWIDTH,DIALHEIGHT,ILI9341_YELLOW, ILI9341_YELLOW, ILI9341_BLACK,"Message",SIZE_TEXT_BUTTON/4);
messageButton.drawButton();*/
return;
eraseButton.initButton(&tft,DELETE_X, DELETE_Y,DELETE_WIDTH,DELETE_HEIGHT,ILI9341_WHITE,ILI9341_WHITE,ILI9341_WHITE,"",SIZE_TEXT_BUTTON);
dialButton.initButton(&tft,DIALX,DIALY,DIALWIDTH,DIALHEIGHT, ILI9341_WHITE,ILI9341_WHITE, ILI9341_WHITE, "",SIZE_TEXT_BUTTON);
/*messageButton.initButton(&tft, MESSAGEX,DIALY,DIALWIDTH,DIALHEIGHT,ILI9341_WHITE, ILI9341_WHITE, ILI9341_WHITE,"",SIZE_TEXT_BUTTON);
void deleteAll()
if(hasCursor)
return;
phoneNumber[0]=0;
ChangeEditButtonsVisiblity(false);
tft.fillRect(PRINT_X_START, DELETE_Y, PRINT_WIDTH,PRINT_HEIGHT, ILI9341_WHITE);
printPhoneNumberToScreen();
void deleteDigit()
if(!hasCursor)
int phoneLength=strlen(phoneNumber);
if(phoneLength==0)
return;
phoneNumber[phoneLength-1]=0;
if(strlen(phoneNumber)==0)
void printPhoneNumberToScreen()
tft.setCursor(PRINT_X_START , PRINT_Y_START);
tft.setTextColor(ILI9341_BLACK); tft.setTextSize(FONT_SIZE_INPUT_PHONE);
tft.print(phoneNumber);
int pointOfLastTouch()
int finResult=millis();
while(!ts.bufferEmpty())
delay(30);
lastPointChecked=ts.getPoint();
finResult=millis()-finResult;
return finResult;
void mappingThePoint()
lastPointChecked.x=map(lastPointChecked.x, TS_MINX,TS_MAXX,0,ILI9341_TFTWIDTH);
lastPointChecked.y=map(lastPointChecked.y, TS_MINY,TS_MAXY,0,ILI9341_TFTHEIGHT);
void checkifDigitNumPressed()
bool pressed;
pressed=myButtons[i].contains( lastPointChecked.x, lastPointChecked.y);
myButtons[i].press(pressed);
if(pressed)
strcat(phoneNumber,buttonsLabel[i]);
if(strlen(phoneNumber)==1)
ChangeEditButtonsVisiblity(true);
void checkTouch()
bool pressed;
int timepressed;
if(firstTime==true)
checkifDigitNumPressed();
firstTime=false;
return;
timepressed=pointOfLastTouch();
mappingThePoint();
if(strlen(phoneNumber)>0)
pressed=eraseButton.contains(lastPointChecked.x,lastPointChecked.y);
eraseButton.press(pressed);
if(pressed)
if(timepressed<1000)
deleteDigit();
return;
deleteAll();
return;
pressed= dialButton.contains(lastPointChecked.x,lastPointChecked.y);
dialButton.press(pressed);
if(pressed)
//use method on gsm dial(phoneNumber);
Serial.println("Now Dialing");
if(strlen(phoneNumber)== MAXLENGTHPHONENUMBER)
return;
bool BANNED(int num, int mini,int maxi)
if(num<mini||num>maxi)
return false;
// put your setup code here, to run once:
beginAll();
buttonsInit();
drawNumbers();
doUpdate = false;
// put your main code here, to run repeatedly:
if(!ts.bufferEmpty()) checkTouch();
if(doUpdate) drawNumbers();
