RGB LCD Backpack GPA 5
by ATE_ENG on Wed Jun 13, 2018 10:41 am
Looking at the diagram for the RGB LCD Shield Kit w/ 16x2 Character Display I don't see GPA5 being used on the LCD shield or any of the input buttons.
Can I connect another switch (such as the Reed switch shown below) for use as soft reset button?
Although this seems possible, I'm having trouble understanding the MCP23017-E/SP datasheet
If so, what #define would I need to add to the RGBLCDShield Library where:
#define BUTTON_UP 0x08
#define BUTTON_DOWN 0x04
#define BUTTON_LEFT 0x10
#define BUTTON_RIGHT 0x02
#define BUTTON_SELECT 0x01
#define BUTTON_SFTRST 0x##
Furthermore, would I need to make any additional modifications?
ATE_ENG
Re: RGB LCD Backpack GPA 5
by adafruit_support_bill on Wed Jun 13, 2018 10:54 am
Bit 5 would be 0x10
by ATE_ENG on Wed Jun 13, 2018 11:04 am
adafruit_support_bill wrote:Bit 5 would be 0x10
According to the #define, isn't Bit 4 BUTTON_LEFT 0x10?
ATE_ENG
by adafruit_support_bill on Wed Jun 13, 2018 11:15 am
Sorry, they are 0-relative, so bit 5 would be 0x20
by ATE_ENG on Wed Jun 13, 2018 11:32 am
adafruit_support_bill wrote:Sorry, they are 0-relative, so bit 5 would be 0x20
No Problem, Now I'm having trouble with this function
uint8_t Adafruit_RGBLCDShield::readButtons(void) {
  uint8_t reply = 0x1F;
  for (uint8_t i=0; i<5; i++) {
    reply &= ~((_i2c.digitalRead(_button_pins[i])) << i);
  return reply;
It seems like I need to change the initial value of reply in order to capture pin 5 setting it to 0x20 seems to capture a pin that is being held to ground.
ATE_ENG
by adafruit_support_bill on Wed Jun 13, 2018 11:37 am
You need to mask in the extra bit to start - then loop through all of the bits you are trying to read:
  uint8_t reply = 0x3F;
  for (uint8_t i=0; i<6; i++) {
  return reply;
by ATE_ENG on Wed Jun 13, 2018 12:18 pm
adafruit_support_bill wrote:You need to mask in the extra bit to start - then loop through all of the bits you are trying to read:
  return reply;
For posterity, I also had to modify RGBLCDShield::begin to
      _i2c.pinMode(_button_pins[i], INPUT);
      _i2c.pullUp(_button_pins[i], 1);
The modified library with the RGB LCD Shield Interrupt-On-Change modification Is attached.
Adafruit_RGB_LCD_Shield_Library.zip
(14.79 KiB) Downloaded 8 times
ATE_ENG
by adafruit_support_bill on Wed Jun 13, 2018 12:20 pm
Nice! Thanks for posting your code.
