Turn off stepper motors for heat?
- kifling
I've got a small project, where I am using some stepper motors to perform a function once or twice a day. However, the power is constant and very hot. Seems unneccesary. Is there a way to turn off power to the steppermotor when it's idle? I've got an adafruit motor shield, so using the motorsheild library.
- adafruit_support_bill
Re: Turn off stepper motors for heat?
You can call the "release()" function to turn off holding current to the motor.
- kifling
Thank you. A bit of a clarification.
I currently call the steppers
myMotorRight
and
myMotorLeft
I call them this way
myMotorRight->step(1, BACKWARD, SINGLE);
I'm not quite sure how to invoke the release. Looking online, I see that it might be
myMotorLeft.release();
myMotorRight.release();
but that comes up with an error suggesting
myMotorLeft->release();
myMotorRight->release();
Is this correct?
myMotorRight
and
myMotorLeft
Is this correct?
When using the V2 motor shield library, the 'motors' in your code are actually pointers to motor objects.
Since they are pointers, you need to use the '->' instead of the '.'
- kifling
thanks so much.
