Data logger shield/timestamp
Re: Data logger shield/timestamp
by hginvt on Wed Sep 12, 2018 12:21 am
I've been struggling with and can't figure it out. The sketch/shield write data to the SD card if I comment out the IF Statement and allow control only by the delay command. It does not write to the SD card if I include the IF statement. Its does print to the serial port/screen as expected, but will only write to SD card without IF statement.
// Work in Progress 27 Aug 2018
// Developing first data logging sketch
// read temperature sensor and log readings of deg C and deg F to SD card
// 28 August-- sucessfully write data to SD card, next add switch to control data logging
// 29 August-- switch added. Jumper Pin 3 to 3.3 volts to logg data, jumper to GRN to not log data
//               note: need to "re-set" Arduino after re-inserting SD card
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <SD.h>
#include <SPI.h>
#include "RTClib.h"
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd (0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
#define ONE_WIRE_BUS 7
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
 float Celcius=0;
 float Fahrenheit=0;
 int inputPin=3; // jumper Pin 3 to 3.3 volts to write data to SD card, to GRN to not write to SD
 int chipSelect = 4; // chipSlect pin for the SD card reader
 File myFirstData; //Data object you will write your sensor data to
 RTC_PCF8523 rtc;
 int x; //value of Mudulo divide
 int dlSwitch; // jumper to control logging of data
 int dlSwitch2;
 int counter = 0;
void setup(void)
   // following line sets the RTC to the date & time this sketch was compiled
   rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
   // This following code would set the RTC with an explicit date & time, for example
   // January 21, 2014 at 3am you would call:
   // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
  Serial.begin(9600);
  sensors.begin();
  rtc.begin();
  pinMode(inputPin, INPUT);
  pinMode(10, OUTPUT); //Must declare 10 an output and reserve it
  SD.begin(4); //Initialize the SD card reader
    //Add for LCD
    lcd.begin(20,4);
    lcd.backlight();
    lcd.setCursor(0,0);
    lcd.clear();
void loop(void)
 myFirstData=SD.open("My_Data.txt", FILE_WRITE);
  sensors.requestTemperatures();
  Celcius=sensors.getTempCByIndex(0);
  Fahrenheit=sensors.toFahrenheit(Celcius);
  DateTime now = rtc.now(); //get current date&time from rtc
//print time with leading zeros
  char printLineA[10]; // This will hold the Date
  char printLineB[8]; // This will hold the Time
  sprintf(printLineA,"%02d/%02d/%4d", now.month(), now.day(), now.year());
  sprintf(printLineB,"%02d:%02d:%02d", now.hour(), now.minute(), now.second());
// Display on LCD
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print(printLineA);
  lcd.print(" ");
  lcd.print(printLineB);
  lcd.setCursor(13,2);
  lcd.print(Celcius);
  lcd.print(" C");
  lcd.setCursor(13,3);
  lcd.print(Fahrenheit);
  lcd.print(" F");
//create "mechcanical switch": possble way to control logging
dlSwitch = digitalRead(inputPin); // readcPin3 Hi or LOW
//create a counter: another possible way to control logging
counter = counter + 1;
//Use IF statement to control when to write to SD card
if ((now.second() == 00 || now.second() == 01))
//Print to Serial Port/screen TimeStamp and data
 //print timestamp
 Serial.print(printLineA);
 Serial.print(" ");
 Serial.print(printLineB);
 Serial.print(" ");
 // print data
 Serial.print(Celcius);
 Serial.print(", ");
 Serial.print(Fahrenheit);
//Mudulo Divide -- base it off Unix Time
// if resulant of Mudulo divide of Unix time by 60 is zero (or 1 accoumting for imprecision of timing)
// one minute has elapsed -- write to SD card
x = now.unixtime()%60;
Serial.print(", ");
Serial.print(x);
Serial.print(", ");
Serial.print(dlSwitch);
Serial.print(", ");
Serial.print(dlSwitch2);
Serial.print(", ");
Serial.print(counter);
// end Mudulo divide
Serial.println();
// Write to SD card
 Serial.print("  Log Record");
 myFirstData.print(printLineA);
 myFirstData.print(" ");
 myFirstData.print(printLineB);
  myFirstData.print(Celcius);
  myFirstData.println(Fahrenheit);
  myFirstData.close();
counter = 0;
// delay 304 for one second execution interval
  delay(1304);
sketch_temperature1a_SD_LCD.ino
(3.9 KiB) Downloaded 6 times
Last edited by adafruit_support_bill on Wed Sep 12, 2018 12:31 pm, edited 1 time in total.
Reason: added code in-line
hginvt
by adafruit_support_bill on Wed Sep 12, 2018 6:50 am
Please post a sample of the serial output with the IF statement enabled.
by hginvt on Wed Sep 12, 2018 12:19 pm
I've uploaded a screen shot of the serial output with the IF statement operative and a copy/past of the output as well.
Thank you.
09/12/2018 09:02:00 20.06, 68.11, 0, 1, 0, 12
  Log Record09/12/2018 09:03:00 20.12, 68.22, 0, 1, 0, 30
  Log Record09/12/2018 09:04:00 20.25, 68.45, 0, 1, 0, 30
  Log Record09/12/2018 09:05:00 20.25, 68.45, 0, 1, 0, 30
  Log Record09/12/2018 09:06:00 20.31, 68.56, 0, 1, 0, 30
  Log Record09/12/2018 09:07:00 20.31, 68.56, 0, 1, 0, 30
  Log Record09/12/2018 09:08:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:09:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:10:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:11:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:12:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:13:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:14:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:15:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:16:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:17:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:18:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:19:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:20:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:21:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:22:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:23:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:24:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:25:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:26:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:27:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:28:00 20.31, 68.56, 0, 1, 0, 30
  Log Record09/12/2018 09:29:00 20.31, 68.56, 0, 1, 0, 30
  Log Record09/12/2018 09:30:00 20.31, 68.56, 0, 1, 0, 30
  Log Record09/12/2018 09:31:00 20.31, 68.56, 0, 1, 0, 30
  Log Record09/12/2018 09:32:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:33:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:34:00 20.50, 68.90, 0, 1, 0, 30
  Log Record09/12/2018 09:35:00 20.50, 68.90, 0, 1, 0, 30
  Log Record09/12/2018 09:36:00 20.50, 68.90, 0, 1, 0, 30
  Log Record09/12/2018 09:37:00 20.50, 68.90, 0, 1, 0, 30
  Log Record09/12/2018 09:38:00 20.50, 68.90, 0, 1, 0, 30
  Log Record09/12/2018 09:39:00 20.50, 68.90, 0, 1, 0, 30
  Log Record09/12/2018 09:40:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:41:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:42:00 20.44, 68.79, 0, 1, 0, 30
  Log Record09/12/2018 09:43:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:44:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:45:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:46:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:47:00 20.37, 68.68, 0, 1, 0, 30
  Log Record09/12/2018 09:48:00 20.31, 68.56, 0, 1, 0, 30
  Log Record
SampleOfSerialPortWithIFStatement.txt
(2.71 KiB) Downloaded 9 times
Last edited by adafruit_support_bill on Wed Sep 12, 2018 12:30 pm, edited 1 time in total.
Reason: posted output in-line
hginvt
by adafruit_support_bill on Wed Sep 12, 2018 12:36 pm
When posting code or text-data, please post it in-line using the [code] button. That is much easier to deal with than attachments.
Your code appears to be printing the data every minute as it should. I don't see anywhere that you close or flush the file, so the directory entry for the file is probably not getting written or updated.
by hginvt on Wed Sep 12, 2018 4:43 pm
Thank you for your support.
I have uploaded the file again with line numbers. I have had a close statement at line 170. I did try adding a flush statement, to no success.
What totally baffles me is that when I comment out the IF statement it works perfectly, logging the intended data every 2 seconds. What is it about an IF statement that can cause the sketch to not print the data to the SD card?
(3.9 KiB) Downloaded 4 times
hginvt
by adafruit_support_bill on Wed Sep 12, 2018 7:00 pm
by hginvt on Wed Sep 12, 2018 10:42 pm
I thought I had: My apologies.
I have got it to work. The command line defining the text file and opening the SD card to write ( myFirstData=SD.open("My_Data.txt", FILE_WRITE);) needed to be within the IF statement testing if it was a new minute. I don't understand why following the flow of the program, but when I moved the command from the general loop to within that IF statement the sketch writes the data to the file minutely.
Thanks for al your support
hginvt
by bps on Thu Sep 13, 2018 1:48 pm
I'm having a time and date problem as well. I am using an 1141 datalogger shield with an actual UNO powered through a USB port. I am running the pfc8523 sketch which I have not changed in any way. I get a date that is about 11 months and some days ahead and, if I am reading things correctly, I get a return saying that today is Monday when it is actually Thursday. Could you suggest what the problem might be. I also unplugged the UNO and removed the coin cell for about 15 seconds before rebooting.
bps
by adafruit_support_bill on Thu Sep 13, 2018 2:35 pm
You need remove & replace the coin cell and uncomment the rtc.adjust line in setup() to initialize the time.
  if (! rtc.initialized()) {
    Serial.println("RTC is NOT running!");
    // This line sets the RTC with an explicit date & time, for example to set
by bps on Thu Sep 13, 2018 3:24 pm
I have used the same coin cell on another datalogger (an older one) and the rtc on the datalogger gives the correct information. The data adjust line was already uncommented. I could not manual set the date and time using the other function.
bps
by adafruit_support_bill on Thu Sep 13, 2018 3:35 pm
Please post photos showing your soldering and any connections to the shield.
by bps on Thu Sep 13, 2018 4:47 pm
I'll send you pix tomorrow
bps
by bps on Fri Sep 14, 2018 10:34 am
I attach a picture. I also attach the output from the Serial Monitor. BTW, I installed a new battery.
RTC is NOT running!
2165/165/165 (Thursday) 165:165:85
since midnight 1/1/1970 = 1580946385s = 18297d
now + 7d + 30s: 2020/2/13 12:16:31
bps
by adafruit_support_bill on Fri Sep 14, 2018 10:37 am
That indicates an i2c communication problem. Is the UNO you are using an R3, or an earlier version? If you are not sure, post a photo of your UNO.
by bps on Fri Sep 14, 2018 4:32 pm
I think it is an earlier version. I believe that I also have an R3. If it is any help help, I tried this with a sparkfun red board with the same results.
bps
