Pin7 Breakout for PCF8523 on SD Shield
by fsonnichsen on Thu Jan 10, 2019 2:41 pm
I need to read the PCF8523 interrupt pin (7) on the SD datalogging shield. I do not see this pin mapped to a header in the layout. Short of a fly-wire is this pin available somewhere on the board?
Fritz
fsonnichsen
Re: Pin7 Breakout for PCF8523 on SD Shield
by millercommamatt on Thu Jan 10, 2019 3:47 pm
If I'm reading the schematic (https://learn.adafruit.com/assets/66497) correctly, there's a through hole in the middle of the board that should be what you want. It's labeled SQ. It's between holes labeled 3V and WP.
millercommamatt
by fsonnichsen on Thu Jan 10, 2019 4:17 pm
aha-thanks. Now I see it. It is labled CN1 in the schematic (but not labeled on the board). I ohmed it out and you are correct.
cheers
fritz
fsonnichsen
by adafruit_support_carter on Thu Jan 10, 2019 8:44 pm
Yep. That pin is multifunctional (see datasheet). The silk references the square wave output, CLKOUT. But it's a straight connection to Pin 7 of the PCF so is also INT1:
