MusicMaker shield with touch sensor coding question
Re: MusicMaker shield with touch sensor coding question
by adafruit_support_bill on Thu Sep 05, 2019 12:21 pm
The first number in the output is the reading from the A0 pin. The second number is the value of 'playingMusic '. According to the output, the music is playing (the value is 1) when you lift your finger and it calls pause.
Are you sure that the track001.mp3 is good? What happens if you play the full file?
by moonmansays on Thu Sep 05, 2019 12:41 pm
If I change startPlayingFile to playFullFile, the entire file plays. To be clear about the serial monitor numbers relative to my actions:
When I press the touch sensor, this is printed in the serial monitor:
670
Playing track 001
and when I release the touch sensor, this is printed in the serial monitor:
14
1
Paused
The first numbers of these groups are slightly different each time but the second numbers are consistent each time -- and 0 is always displayed with the playing of the file upon my touching the sensor, and 1 is always displayed after I release the sensor. It has never displayed a '1' upon touching the sensor.
moonmansays
by adafruit_support_bill on Thu Sep 05, 2019 1:44 pm
Exactly as expected. Follow the logic of the loop:
670 - you are pressing the button
0 - the track is not playing yet
Playing track 001 - now you start playing the track. You will stay in the 'while' loop until you lift your finger.
14 - you are no longer pressing the button
1 - but the track is still playing
Paused - until you tell it to pause - You will stay in the 'while' loop until youpress teh button again.
Looking at the rest of your code, the problem seems to be that you are not enabling the interrupts. When using the asynchronous 'startPlayingFile' function, the library needs to use periodic interrupts to keep the music player supplied with fresh mp3 data to play.
See the example here:
https://github.com/adafruit/Adafruit_VS ... rrupts.ino
by moonmansays on Thu Sep 05, 2019 2:12 pm
Amazing! Yes, that's what was needed. It now works as I had hoped! Thank you so much for continuing to help me troubleshoot and for the lessons in code logic and reading the serial monitor. I now understand better how it reads the code and where code needs to be placed. I'm still not sure I understand why something called an interrupt is needed but I am happy to have working code. Next is figuring out how to provide an audio tail once the sensor is released so that the musical note doesn't end abruptly. Do you know if the MusicMaker is capable of jumping to the tail end of the sound file it is playing and playing just the end of the file when the sensor is released? Or alternatively, if once the sensor is released, the sound fades out instead of cutting off abruptly? Thank you very much Bill for helping me solve this challenge. I now have a working device! - Chris
moonmansays
by adafruit_support_bill on Thu Sep 05, 2019 2:40 pm
The interrupt is needed because the processor can only do one thing at a time. While it is sitting there in the 'while' loop, it is not feeding data to the sound chip. If you enable the interrupts, it will periodically interrupt your while loop and call a function in the library that will feed another buffer's worth of data before returning to your loop.
To make it jump to the end is probably possible, but not trivial. Fading out would probably be easier. There is a setvolume function in the library. You can call that in a loop to fade out the sound.
by moonmansays on Thu Sep 05, 2019 2:57 pm
Thanks for the explanation and the directions for finding the setvolume fade function. I will find and implement it. But here's something... I've been playing with this now and it works great but there is a little glitch. Once the program is uploaded, the file plays cleanly the first time I press and release the sensor. But all subsequent times I press the sensor, the file begins with a sonic glitch. It appears to be some leftover sonic material from the end of the last time it was played. Is there any way to reset each time so this doesn't happen? Or some other solution? Thank you again for all your help.
Update: I got the volume fade function to work. It sounds great. But the starting glitch is still there.
moonmansays
by adafruit_support_bill on Thu Sep 05, 2019 3:18 pm
Not sure if it will help, but you can try calling musicPlayer.begin() again to see if that resets things sufficiently.
by moonmansays on Thu Sep 05, 2019 3:28 pm
It worked! Thanks. I put the line at the end of the final commands. I'm attaching my finalized code. Does it all look clean to you?
  AnalogReadSerial
  Reads an analog input on pin 0, prints the result to the Serial Monitor.
  Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/AnalogReadSerial
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
//#define CLK 13       // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  //Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
   if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  if (! musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT))
    Serial.println(F("DREQ pin is not an interrupt pin"));
// the loop routine runs over and over again forever:
        void loop()  {
       // read the input on analog pin 0:
       int sensorValue = analogRead(A0);
       Serial.println(sensorValue);
       Serial.println(musicPlayer.playingMusic);
       int threshold = 200;
       int v = 0; //volume
       // Only start playing if not already playing
       if(sensorValue > threshold)
        //volume fade in
      for (v = 140; v > 19; v--){
        musicPlayer.setVolume(v,v);
        delay (0);}
          Serial.println(F("Playing Sound"));
          musicPlayer.startPlayingFile("BFSSUSC3.mp3");
          while(analogRead(A0) > threshold)
             // do nothing
       else // stop playing
        //volume fade out
      for (v = 20; v < 140; v++){
         delay (10);}
          Serial.println(F("Paused"));
          musicPlayer.pausePlaying("BFSSUSC3.mp3");
          while(analogRead(A0) <= threshold)
          musicPlayer.begin();
             // do nothing
moonmansays
by adafruit_support_bill on Thu Sep 05, 2019 3:59 pm
Looks good! Thanks for the follow-up.
by moonmansays on Mon Sep 16, 2019 9:47 am
Thank you for your help earlier this month. I am starting to import different sound files into the MusicMaker and have discovered that for some reason the file fades on its own after about 6 seconds even if the sensor is still being touched. My first uploaded file was under this threshold so I didn't pick up on this earlier. Can you please look at my code and tell me if you see anything that would cause this behavior? Thank you!
      AnalogReadSerial
    #include <SPI.h>
    #include <SD.h>
      Serial.begin(9600);
         while (1);
            void loop()  {
           int v = 0; //volume
            //volume fade in
            delay (0);}
                 // do nothing
            //volume fade out
             delay (10);}
                 // do nothing
moonmansays
by adafruit_support_bill on Sun Sep 22, 2019 8:32 am
Look at the serial output when that occurs and see what the sensor value is. You may need to adjust your threshold value.
by moonmansays on Mon Sep 23, 2019 11:17 am
Thanks for looking into this with me, Bill. The threshold value has been 200. I tried a value of 1000, a value of 1 and also 0. Nothing changes. The audio file fades after 6 or 7 seconds even though my finger remains on the touch sensor. I opened the serial monitor and took a screenshot for you to see (attached) what happens when I put my finger on the sensor without lifting it off. Thank you for your help!
Screen Shot 2019-09-23 at 11.01.42 AM.png (30.19 KiB) Viewed 69 times
moonmansays
by adafruit_support_bill on Mon Sep 23, 2019 11:33 am
Your output clearly shows that the sensor value is 0 on the second pass. And the code is pausing as would be expected.
So whatever you are using as a touch sensor does not think you are touching it anymore.
by moonmansays on Mon Sep 23, 2019 11:56 am
Ok. These are what I am using... Is it possible that they somehow timeout internally? That they aren't meant to be held onto for so long? I have tried a few of them and they all react the same way.
Screen Shot 2019-09-23 at 11.46.46 AM.png (930.88 KiB) Viewed 63 times
moonmansays
by adafruit_support_bill on Mon Sep 23, 2019 12:42 pm
I'm not familiar with those boards. But capacitive sensors typically need to re-calibrate periodically - which can limit the maximum ON-duration. Our momentary boards default to a 60 second maximum ON duration..
https://www.adafruit.com/product/1374
