📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
SD Card failed (Arduino - Shield SD)
by fdelabriere on Wed Sep 04, 2019 9:22 am
Hi to all,
my project is stopped...
I need a SD card and i used the last exemple for driving my SD Card with "Card SDHC 8GB 133x Speed" formated with my Mac App "SD Card Formatter" and this code below:
#include <SPI.h>
#include <SD.h>
// Adafruit SD shields and modules: pin 10
const int chipSelect = 10;
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
No way !
Initializing SD card...initialization failed. Things to check:
Can you help me ? Do i need to buy a SD Card from your store ?
Thanks a lot for your precious help.
Franck.
fdelabriere
Re: SD Card failed (Arduino - Shield SD)
by dastels on Wed Sep 04, 2019 9:29 am
The list of things to check (and double check) is good. Since you are using a shield, wiring shouldn't be an issue, but double check the chip select pin. The card should be formatted with FAT.
You don't need to buy a card from Adafruit.
Which shield are you using?
dastels
by fdelabriere on Wed Sep 04, 2019 10:35 am
Hi Dave,
how can i "...but double check the chip select pin..." ?
Software:
The code is a copy of the last exemple took from the arduino.cc "Arduino web editor"
Hardware:
I just connected the shield upon the Arduino uno and add a small battery for the Clock.
I sent you a picture of the hardware. Do i have to do something on it ?
Thanks a lot,
Franck.
Capture d’écran 2019-09-04 à 16.28.27.png (108.82 KiB) Viewed 130 times
fdelabriere
by adafruit_support_carter on Wed Sep 04, 2019 12:55 pm
Are the header pins soldered on?
by dastels on Wed Sep 04, 2019 4:32 pm
I'm wondering about the header pins as well. They should be inserted from the bottom of the board. and soldered on top. See https://learn.adafruit.com/adafruit-data-logger-shield/installing-the-headers
dastels
by fdelabriere on Fri Sep 06, 2019 1:42 pm
Hi Dave,
in order to check, i just unsolder all the pins and keep the x6 for main signales and wrap the pin 10 with the CS pin of the shield !
I add my Hantek scope on this pin and confirm that:
1- The shield light are blinking when upload soft into the arduino uno
2- The pin 10 begin with Zero volt and jump to 4,83 V, so High level in order to adress the SD Shield.
But, the Monitor send me the same msg:
"Initializing SD card...initialization failed. Things to check:
I am a bit despite...
Regards,
Franck.
fdelabriere
by adafruit_support_carter on Mon Sep 09, 2019 12:19 pm
It's a little confusing what you did here. Can you post new photos showing both sides of the shield in its current state.
