MAX31855 only reads when I touch board
by jamesgame66 on Sat Nov 21, 2020 8:11 am
Using the sample serialthermocouple code and a K type sensor (I've tried at least 4) I cannot get a constant reading of the internal and thermocouple temperature unless I hold the MAX31855 board between my thumb and forefinger and they are in contact with the components on the attached photo.
Excuse my lack of intimate knowledge of electronics but it seems that I am shorting or somehow affecting one or more of these components through my skin. I have tried two different MAX31855 boards and had exactly the same behaviour.
To be clear, if I dont touch the board then all measurements are reported as 0.00 but when I touch and hold the board then I get something close to the correct thermocouple temperature,
jamesgame66
Re: MAX31855 only reads when I touch board
by adafruit_support_bill on Sat Nov 21, 2020 12:03 pm
Please post photos showing all of your soldering and connections to the board.
by jamesgame66 on Sat Nov 21, 2020 12:41 pm
Here are the connections
jamesgame66
by adafruit_support_bill on Sat Nov 21, 2020 2:14 pm
Please post some photos showing your soldering on the board.
by jamesgame66 on Sat Nov 21, 2020 2:29 pm
I havent carried out any soldering on the MAX31855 if that is what you mean
jamesgame66
by adafruit_support_bill on Sat Nov 21, 2020 3:36 pm
If you did not solder the headers to the board then it will not work reliably.
by jamesgame66 on Sat Nov 21, 2020 5:01 pm
The headers are pre-soldered to the board as per this photograph
jamesgame66
by adafruit_support_bill on Sat Nov 21, 2020 11:00 pm
That is not an Adafruit board. You should contact the seller of the board for technical assistance.
