JST Neopixel connector on Matrix Portal M4 not working
by LEDLIT1 on Sat Feb 27, 2021 5:01 pm
I connect my neopixel strip to the JST connector (Pin A0) on-board my Matrix Portal M4 but it's not lighting up. I am using the Arduino IDE to upload neopixel examples like Strandtest or FastLED Cylon, but no luck. I checked with my volt meter and confirmed the pin configuration is correct. I have tried the other available pins as well (A1, A2, A3, A4, RX, TX, 14, 15, 16, 17, 18, 0, 1) but still not turning on the Neopixels. Please help. I am stuck.
LEDLIT1
Re: JST Neopixel connector on Matrix Portal M4 not working
by dastels on Sat Feb 27, 2021 5:34 pm
Did you change the voltage jumper just behind the JST connector from 5v to 3.3v?
If you're powering the NeoPixels from 5v they very well may not respond to the 3.3v logic signal. Change that jumper to power the connector with 3.3v and I would expect them to work if the strip isn't too long. I've run a couple dozen Pixels at 3.3 with no problems. If you need more pixels, you'll need to power them at 5v and use a level shifter.
See https://learn.adafruit.com/adafruit-neopixel-uberguide for all things NeoPixel related.
dastels
by LEDLIT1 on Sat Feb 27, 2021 7:51 pm
Thank you for the quick reply. I was checking things again with my meter and discovered my connector was the issue. I fixed the connector and tested my 8 neopixels and strandtest worked. Hurray!
Now a New problem with the same set up. I tested FastLED Cylon and it has an error compiling. Please see error messages below. I believe it has something to do with the pin/port, but I am not sure how to get it working. Can you help with this?
Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "Adafruit Matrix Portal M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), Arduino, Off"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jlcel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jlcel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jlcel\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_matrixportal_m4:cache=on,speed=120,opt=small,maxqspi=50,usbstack=arduino,debug=off -vid-pid=239A_80C9 -ide-version=10813 -build-path C:\Users\jlcel\AppData\Local\Temp\arduino_build_97829 -warnings=default -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.bossac.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.openocd.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -verbose C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_410521\Cylon.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jlcel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jlcel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jlcel\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_matrixportal_m4:cache=on,speed=120,opt=small,maxqspi=50,usbstack=arduino,debug=off -vid-pid=239A_80C9 -ide-version=10813 -build-path C:\Users\jlcel\AppData\Local\Temp\arduino_build_97829 -warnings=default -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.bossac.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.openocd.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -verbose C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_410521\Cylon.ino
Using board 'adafruit_matrixportal_m4' from platform in folder: C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.5
Using core 'arduino' from platform in folder: C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.5
Detecting libraries used...
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\sketch\\Cylon.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for FastLED.h: [FastLED@3.4.0]
ResolveLibrary(FastLED.h)
  -> candidates: [FastLED@3.4.0]
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\sketch\\Cylon.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\FastLED.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\bitswap.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\colorpalettes.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\colorutils.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\hsv2rgb.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\lib8tion.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\noise.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\platforms\\esp\\32\\clockless_rmt_esp32.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\platforms.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\power_mgt.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src\\wiring.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\sketch\\Cylon.ino.cpp" -o "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"Cylon.ino\"\"\"" -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\sketch\\Cylon.ino.cpp" -o "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_97829\\sketch\\Cylon.ino.cpp.o"
In file included from C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_410521\Cylon.ino:1:
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/FastLED.h:585:2: warning: #warning "No pin/port mappings found, pin access will be slightly slower. See fastpin.h for info." [-Wcpp]
  585 | #warning "No pin/port mappings found, pin access will be slightly slower. See fastpin.h for info."
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
   14 | #    pragma message "FastLED version 3.004.000"
In file included from C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/FastLED.h:65,
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/fastspi.h:135:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
  135 | #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
In file included from C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/FastLED.h:48,
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/fastpin.h: In instantiation of 'class FastPin<23>':
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/platforms/arm/d51/clockless_arm_d51.h:19:49:   required from 'class ClocklessController<23, 30, 75, 45, RGB, 0, false, 50>'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/chipsets.h:578:7:   required from 'class WS2812Controller800Khz<23, RGB>'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/FastLED.h:103:52:   required from 'class WS2812<23, RGB>'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/FastLED.h:302:39:   required from 'static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2812; unsigned char DATA_PIN = 23; EOrder RGB_ORDER = RGB]'
C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_410521\Cylon.ino:18:49:   required from here
C:\Users\jlcel\Documents\Arduino\libraries\FastLED\src/fastpin.h:210:24: error: static assertion failed: Invalid pin specified
  210 |  static_assert(validpin(), "Invalid pin specified");
Using library FastLED at version 3.4.0 in folder: C:\Users\jlcel\Documents\Arduino\libraries\FastLED
exit status 1
Error compiling for board Adafruit Matrix Portal M4 (SAMD51).
LEDLIT1
by dastels on Sat Feb 27, 2021 8:34 pm
Yes, it doesn't like the pin. Do any other fastLED demos compile?
dastels
by LEDLIT1 on Sat Feb 27, 2021 8:44 pm
I tried every fastLED example. they all had the same error message.
LEDLIT1
by dastels on Sun Feb 28, 2021 3:22 pm
I've never dug into FastLED deep enough to really help with that, other than it's probably a config issue.
dastels
by LEDLIT1 on Sun Feb 28, 2021 5:40 pm
Yes, a config issue in the FastPin.h file. The library needs to be updated for the Adafruit Matrix Portal M4 (SAMD51) . That may be a simple task for some, but it a vast unknown for me. I will still read and search in the code a little more, with the hopes that I can add or modify.
I posted this issue on https://github.com/FastLED/FastLED/issues/1196 . Maybe someone there can update the library as needed. I imagine that will take a while.
So in the meantime I guess I'll go back to my ESP32 Feather Hazzah32 with my modified Featherwing for M4 SAMD51.
LEDLIT1
