Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
PPS signal of ultimate gps 3 unusable suddenly
by flok on Thu Dec 02, 2021 5:34 pm
I have connected to a raspberry pi an adafruit ultimate gps 3.
Suddenly the pps signal is (compared to other gps'es and ntp servers on the internet) several 100ms mis-ticking.
I thought it could be broken so I took an other adafruit ultimate gps 3: same problem.
Then I swapped the raspberry pi: same problem.
What could be the cause? Both gpses broken? Or?
flok
Re: PPS signal of ultimate gps 3 unusable suddenly
by flok on Sat Dec 04, 2021 4:09 pm
Tried a different antenna as well and a different location (both times with clear view of the sky) and it made no difference.
flok
by sj_remington on Sun Dec 05, 2021 12:12 am
Does the GPS have a satellite fix? Record some NMEA sentences and post them (RMC type is enough).
sj_remington
by flok on Sun Dec 05, 2021 7:00 am
It does:
(71) $GPGGA,105757.000,5201.6746,N,00441.7433,E,1,7,1.24,4.8,M,47.1,M,,*54
(56) $GPGSA,A,3,05,09,07,02,14,20,30,,,,,,1.51,1.24,0.86*03
(70) $GPRMC,105757.000,A,5201.6746,N,00441.7433,E,0.60,8.87,051221,,,A*6C
(35) $GPZDA,105757.000,05,12,2021,,*50
flok
by adafruit_support_mike on Sun Dec 05, 2021 9:41 pm
It's very unlikely to have multiple random failures that all behave the same way.
The first thing I'd suspect would be a software issue. Did you change or update/upgrade any code since the last time the PPS worked as expected?
by flok on Tue Dec 07, 2021 2:16 pm
Well, I have 4 raspberry pi's that all run the same ntpsec (ntpd, and gpsd where applicable). Now only the pi's with the adafruit shield show this odd behaviour.
flok
by adafruit_support_mike on Tue Dec 07, 2021 11:14 pm
If you swap the GPS module from one RasPi to another, does the problem follow the module or stay with the RasPi?
by flok on Wed Dec 08, 2021 11:19 am
It follows. I swapped raspberry's and antenna's.
flok
by adafruit_support_mike on Wed Dec 08, 2021 8:25 pm
Thank you.
This is the first time I've heard of a GPS module's PPS falling out of sync with the constellation's clock. When did you get the GPS modules?
by flok on Sat Dec 11, 2021 1:40 am
At least(!) more than 5 years ago.
flok
by adafruit_support_mike on Sat Dec 11, 2021 10:34 pm
At that age, it could be almost anything.
The fact that you're seeing the same issue in two modules suggests a problem that might be related to firmware, so you can try updating that:
https://learn.adafruit.com/adafruit-ult ... aq-2954734
I can't make any promises, but it can't hurt.
by flok on Sun Dec 12, 2021 8:07 am
Thank you. I'll see if I can find a windows pc for that.
I'll let you know if it helped.
flok
