PPS signal of ultimate gps 3 unusable suddenly
flok
Post by flok »
I have connected to a raspberry pi an adafruit ultimate gps 3.
Suddenly the pps signal is (compared to other gps'es and ntp servers on the internet) several 100ms mis-ticking.
I thought it could be broken so I took an other adafruit ultimate gps 3: same problem.
Then I swapped the raspberry pi: same problem.
What could be the cause? Both gpses broken? Or?
flok
Re: PPS signal of ultimate gps 3 unusable suddenly
Post by flok »
Tried a different antenna as well and a different location (both times with clear view of the sky) and it made no difference.
sj_remington
Post by sj_remington »
Does the GPS have a satellite fix? Record some NMEA sentences and post them (RMC type is enough).
flok
Post by flok »
It does:
(71) $GPGGA,105757.000,5201.6746,N,00441.7433,E,1,7,1.24,4.8,M,47.1,M,,*54
(56) $GPGSA,A,3,05,09,07,02,14,20,30,,,,,,1.51,1.24,0.86*03
(70) $GPRMC,105757.000,A,5201.6746,N,00441.7433,E,0.60,8.87,051221,,,A*6C
(35) $GPZDA,105757.000,05,12,2021,,*50
adafruit_support_mike
It's very unlikely to have multiple random failures that all behave the same way.
The first thing I'd suspect would be a software issue. Did you change or update/upgrade any code since the last time the PPS worked as expected?
flok
Post by flok »
Well, I have 4 raspberry pi's that all run the same ntpsec (ntpd, and gpsd where applicable). Now only the pi's with the adafruit shield show this odd behaviour.
If you swap the GPS module from one RasPi to another, does the problem follow the module or stay with the RasPi?
flok
Post by flok »
It follows. I swapped raspberry's and antenna's.
Thank you.
This is the first time I've heard of a GPS module's PPS falling out of sync with the constellation's clock. When did you get the GPS modules?
flok
Post by flok »
At least(!) more than 5 years ago.
At that age, it could be almost anything.
The fact that you're seeing the same issue in two modules suggests a problem that might be related to firmware, so you can try updating that:
https://learn.adafruit.com/adafruit-ult ... aq-2954734
I can't make any promises, but it can't hurt.
flok
Post by flok »
Thank you. I'll see if I can find a windows pc for that.
I'll let you know if it helped.
