No dc ouput on motor shield terminals
chrisgrant72
Post by chrisgrant72 »
Please help,
Im 100% sure everthing is wired correctly see photos , arduino is receiving code and blink test is working ( BTW im a newby at this) Fan are not faulty polarity is correct. The adafruit is a V2 and Arduino uno R3 . IDE LIBRARY: MOTOR SHIELD V2 is installed on adafruit. Only issue I can see is a message displayed at bottom right corner after sketch is loaded saying "could not connect to serial port Error. Timeout after 1000ms.
DC motor test does not work no Voltage on motor terminals at all. been going at this for 3 days now and no luck, Pleeeasse help for my sanity!!
Re: No dc ouput on motor shield terminals
Please post the complete code you are using. Also please tell us what kind of Arduino you are using.
chrisgrant72
Arduino UNO R3 and the example DC motor test in the IDE . If I remember right ( it’s late and I’m in bed) tools>examples>adafruit>dc motor test .
Thank you.
Ultimately I’m going to use it in Simhub as a wind simulator
OK. The power indicator LED is on and the wiring looks correct for that sketch.
What motor are you using?
Also, try running the i2c scanner code here and post the results: https://playground.arduino.cc/Main/I2cScanner/
chrisgrant72
The result was:
Not connected. Select a board and a port to connect automatically.
SCANNING....
No I2C device found
chrisgrant72
12v dc 1.4amp fan
The drivers on the shield are only rated for 1.2A.
chrisgrant72
But there would still be a voltage across the terminals in test mode wouldn’t there?
My multimeter is not picking up any voltage at all on all 4 motor terminals with or without a motor connected
The "No I2C device found" indicated a problem communicating with the shield. If you contact [email protected] with a link to this thread we can replace that for you.
Not if the drivers were fried by an overload. Running that fan at 12V risks burning out the drivers. You could probably safely run it at 9 or 10V.
Another alternative is to use a driver with higher current capacity: https://www.adafruit.com/product/3190
chrisgrant72
Ok I’ll buy another board and test it without a load on the output motor terminals to check for a voltage with the program I intend to run on it
No need to buy a new one. Overload is not the immediate cause of the problem. As I said in my previous post, since there is no i2c communication, we can replace it:
Just don't try running that fan at 12v using the shield.
