ESP32-S2 and Data Logger Shield - Card Mount Failed
by charliechesney on Thu Jan 27, 2022 12:50 pm
Hi there. I'm having an issue getting my Adafruit Metro ESP32-S2 to recognize an SD card. I'm using the Adafruit Data Logger shield and using the SD_Test example for the board but the serial monitor says "Card Mount Failed". I know it's not a problem with the SD card or shield because it works on my Adafruit metro board. I'm guessing I need to change a pin in the code for the ESP32 to recognise the SD card, but I'm not sure what, any help?
Here's the SD_Test example code for the Adafruit Metro ESP32-S2:
 * Connect the SD card to the following pins:
 * SD Card | ESP32
 *    D2       -
 *    D3       SS
 *    CMD      MOSI
 *    VSS      GND
 *    VDD      3.3V
 *    CLK      SCK
 *    VSS      GND
 *    D0       MISO
 *    D1       -
#include "FS.h"
#include "SD.h"
#include "SPI.h"
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
    Serial.printf("Listing directory: %s\n", dirname);
    File root = fs.open(dirname);
    if(!root){
        Serial.println("Failed to open directory");
        return;
    if(!root.isDirectory()){
        Serial.println("Not a directory");
        return;
    File file = root.openNextFile();
    while(file){
        if(file.isDirectory()){
            Serial.print("  DIR : ");
            Serial.println(file.name());
            if(levels){
                listDir(fs, file.path(), levels -1);
        } else {
            Serial.print("  FILE: ");
            Serial.print(file.name());
            Serial.print("  SIZE: ");
            Serial.println(file.size());
void createDir(fs::FS &fs, const char * path){
    Serial.printf("Creating Dir: %s\n", path);
    if(fs.mkdir(path)){
        Serial.println("Dir created");
    } else {
        Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path){
    Serial.printf("Removing Dir: %s\n", path);
    if(fs.rmdir(path)){
        Serial.println("Dir removed");
    } else {
        Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path){
    Serial.printf("Reading file: %s\n", path);
    File file = fs.open(path);
    if(!file){
        Serial.println("Failed to open file for reading");
        return;
    Serial.print("Read from file: ");
    while(file.available()){
        Serial.write(file.read());
    file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Writing file: %s\n", path);
    File file = fs.open(path, FILE_WRITE);
    if(!file){
        Serial.println("Failed to open file for writing");
        return;
    if(file.print(message)){
        Serial.println("File written");
    } else {
        Serial.println("Write failed");
    file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Appending to file: %s\n", path);
    File file = fs.open(path, FILE_APPEND);
    if(!file){
        Serial.println("Failed to open file for appending");
        return;
        Serial.println("Message appended");
    } else {
        Serial.println("Append failed");
    file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2){
    Serial.printf("Renaming file %s to %s\n", path1, path2);
    if (fs.rename(path1, path2)) {
        Serial.println("File renamed");
    } else {
        Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char * path){
    Serial.printf("Deleting file: %s\n", path);
    if(fs.remove(path)){
        Serial.println("File deleted");
    } else {
        Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char * path){
    static uint8_t buf[512];
    size_t len = 0;
    uint32_t start = millis();
    uint32_t end = start;
    if(file){
        len = file.size();
        size_t flen = len;
        start = millis();
        while(len){
            size_t toRead = len;
            if(toRead > 512){
                toRead = 512;
            file.read(buf, toRead);
            len -= toRead;
        end = millis() - start;
        Serial.printf("%u bytes read for %u ms\n", flen, end);
        file.close();
    } else {
    if(!file){
        return;
    size_t i;
    start = millis();
    for(i=0; i<2048; i++){
        file.write(buf, 512);
    Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
    file.close();
void setup(){
    Serial.begin(115200);
    if(!SD.begin()){
        Serial.println("Card Mount Failed");
        return;
    uint8_t cardType = SD.cardType();
    if(cardType == CARD_NONE){
        Serial.println("No SD card attached");
        return;
    Serial.print("SD Card Type: ");
    if(cardType == CARD_MMC){
        Serial.println("MMC");
    } else if(cardType == CARD_SD){
        Serial.println("SDSC");
    } else if(cardType == CARD_SDHC){
        Serial.println("SDHC");
    } else {
        Serial.println("UNKNOWN");
    uint64_t cardSize = SD.cardSize() / (1024 * 1024);
    Serial.printf("SD Card Size: %lluMB\n", cardSize);
    listDir(SD, "/", 0);
    createDir(SD, "/mydir");
    removeDir(SD, "/mydir");
    listDir(SD, "/", 2);
    writeFile(SD, "/hello.txt", "Hello ");
    appendFile(SD, "/hello.txt", "World!\n");
    readFile(SD, "/hello.txt");
    deleteFile(SD, "/foo.txt");
    renameFile(SD, "/hello.txt", "/foo.txt");
    readFile(SD, "/foo.txt");
    testFileIO(SD, "/test.txt");
    Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
    Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
void loop(){
charliechesney
Re: ESP32-S2 and Data Logger Shield - Card Mount Failed
by charliechesney on Sat Jan 29, 2022 12:57 am
charliechesney
