Problems with CC3000 Wifi Shield
garyvdg
Post by garyvdg »
I am attempting to use the Adafruit CC3000 wifi shield on an Arduino UNO but do not have complete success with using the example sketches that came with the CC3000 library -- using a fresh version of the library.
The setup seems to be able to connect to my home network OK, but does not appear to be able to go beyond that. For example, the output below is from running the buildtest sketch.
Hello, CC3000!
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Free RAM: 1161
Initialising the CC3000 ...
Firmware V. : 1.24
MAC Address : 0x08 0x00 0x28 0x59 0x84 0xA0
Networks found: 3
SSID Name : SmartRG7912
RSSI : 83
Security Mode: 3
Deleting old connection profiles
Attempting to connect to SmartRG7912
Connected!
Request DHCP
IP Addr: 192.168.1.17
Netmask: 255.255.255.0
Gateway: 192.168.1.1
DHCPsrv: 192.168.1.1
DNSserv: 192.168.2.1
http://www.adafruit.com ->
After this, it just sits there with no further response to the serial monitor.
The second example output below is from using the InternetTime sketch.
Connected!
Request DHCP
Locating time server...
Attempting connection...
connected!
Issuing request...
Awaiting response...error
Current UNIX time: 32 (seconds since 1/1/1970 UTC)
connected!
Issuing request...
Current UNIX time: 63 (seconds since 1/1/1970 UTC)
the printout that says, "Attempting connection..., connected!, Issuing request..." suggests that the device is making connection to the Internet, but then the same response error keeps popping up every 31 seconds.
Could it be that the services the CC300 is attempting to connect to services that no longer exist? Otherwise, what could be the cause of the inability to successfully run the examples?
Thanks.
Franklin97355
Re: Problems with CC3000 Wifi Shield
Post by Franklin97355 »
For some reason the DNS server is on another part of the network and probably not accessable to the CC3000. Try assigning the network statically and see if that helps. https://learn.adafruit.com/adafruit-cc3000-wifi/faq#faq
JohnzBallad
Post by JohnzBallad »
I'm with the same issue.
Franklin97355
JohnzBallad
franklin97355 wrote:For some reason the DNS server is on another part of the network and probably not accessable to the CC3000. Try assigning the network statically and see if that helps. https://learn.adafruit.com/adafruit-cc3000-wifi/faq#faq
Doing that right now. At least trying. It seens that my router doesn't have this option.
JohnzBallad
Now that I'm connecting with a STATIC IP Address is working fine, well... most of it.
Seens like I can't get an answer from dweet.io, for example.
Using this kind of code to receive the answer.
// Lendo a resposta do Host
  Serial.println(F("Reading answer..."));
  while (www.connected()) {
    Serial.println ("Esta connected.");
    while (www.available()) {
      Serial.println("Esta disponivel.");
      char c = www.read();
      Serial.print(c);
  Serial.println(F(""));
But 'www' is not avaiable. Because of that, I can't get the answer.
Any ideas?
You can check my full code, right here: https://github.com/JohnzBallad/johnzbal ... owithdweet
adafruit_support_mike
That would be a DNS failure. It's the system that converts human-readable names like 'www.adafruit.com' to IP addresses.
Check to make sure the CC3000 has an IP address for a DNS server, and make sure the server at that address really does DNS lookups.
herge
Post by herge »
Hi, I am new here and I am sorry if this is not the right place to ask question. If that's the case kindly show me where/who to ask?
I am trying to set up the Adafruit WiFi module CC3000 using Arduino UNO R3 + IDE
I practically follow the instruction step by step as outlined in this link: https://learn.adafruit.com/wifi-weather ... ino-cc3000
- I installed Install the Arduino IDE 1.6.12
- I connected DHT11 to the Arduino UNO : OK I can read temperature + humidity on Serial Monitor – - then I connected the CC3000 to Arduino UNO
- I updated the SSID and PASSWORD accordingly into “buildtest” sketch from ADAFRUIT_CC3000_LIBRARY examples,
- after flashing = OK, it starts and indicates in the Serial Monitor :
Hello, CC3000!
Free RAM: 1161
…then it seems program stops... ???
"Started AP/SSID scan" is not coming out as it is written on page https://learn.adafruit.com/wifi-weather ... ity-sensor
Could you please let me know the causes ? I need your kindly help.
THANK you very much in advance
René
Franklin97355
Try it without any other devices connected and post a picture of your connections between the module and the Uno. Pictures 800x600 work well.
herge
Post by herge »
Thank you for your quick reply
Here are the pictures
René
herge
Post by herge »
hello Franklin
could you please give me an answer ? or a link that can help me ?
Thanks a lot
Franklin97355
I can't tell for sure from the photo angle but check out this Soldering Guide and try making your solders more uniform. Let me know if that helps. Also what are you trying to connect to (router make and model)
