I have a very strange problem.
My BMP280 breakout board gives me wrong results the first time temp and pressure are read after powering on the boar.
The second time (without disconnecting the board), results are ok.
If I try a loop, I have :
power on -> read temp and pressure (wrong results) -> wait and read (good results)
here's an other case:
power on -> read temp and pressure (wrong results) -> wait and read (good results) -> disconnect plus wire and reconnect -> wait and read (wrong results)
Can anyone help me to find what's happening ?
In fact, in any case results are wrong after powering the board. After that, results are always ok.
I use an Arduino pro mini 3.3V, but I have same problem with a 5V board.
BMP280 results are wrong when the board is powered on
- nbenm
- Franklin97355
Re: BMP280 results are wrong when the board is powered on
What are you powering the board with and to what pins? Are the headers soldered?
- nbenm
Hi Franklin,
I'm powering the board with either 3.3V FTDI or 4.5V batteries. Both work fine.
I try to save power. So I have tried:
- BMP280 board + connected to +. - is connected to D5 pin. D5 pin is an output high for the time reading temp and pressure
- same but using MOSFET. Gate to D5 pin, source to GND, and drain to BMP280 minus. And a resistor between pin 5 and GND (10K ohms)
- BMP280 connected to + and -
In all cases, the first read pressure is wrong
All I have found as a workarounds:
temperature = bmp.readTemperature();
pression = (bmp.readPressure()/100.0) + OFFSET;
delay(40);
At the second read, results are correct
The delay is necessary, and a value of 40ms is a minimum for it works.
All headers are soldered
delay(40);
- adafruit_support_mike
That's normal, actually.
The value you get from a BMP280 is the stored result from the previous measurement. Reading the value triggers the next measurement, whose value is stored and returned the next time you call the sensor for a value.
If you put a long delay between readings, or drop and reconnect power, the value you get from the first read won't be valid. The only solution is to do a dummy read to trigger a fresh measurement, then read again to get the data.
- adafruit2
ooh that may be true, added to the FAQ - just read twice :)
