I want to change pin 10 to another pin due to conflicts. I read in another post that you have to change the library WavePinDefs.h to accommodate the new pin. However, when I looked at this file, pin 10 didn't appear like the rest. I'm not really a programmer so not very acquainted with this type of thing. What do I have to change in the file to change pin 10 to pin 1 (if I can even use pin 1) and how do I accommodate "Warning: SS may be redefined as another pin
but the hardware SS_PIN must be set to output mode before any calls to
WaveHC functions"
How to change pin 10 for Wave Shield?
Re: How to change pin 10 for Wave Shield?
You can change the pin number in WaveHC/WavePinDefs.h, but the Arduino SPI library is hardcoded with pin 10 as the default CS/SS pin. If you don't define that pin as an output, the SPI code will fail.
You can use pin 10 for other things as long as it's set as an output.
