I am using motor shield v2.3 stacked on mega 2560 r3 and connected to 2 28byj-48 stepper motors.
Right now I am using a modified version of stepperTest example given along with adafruit library where the number of steps is 4096. and rpm=10
OBSERVATIONS:
only works at forward, double mode with rpm nearly 5 with a lot of heat
in backward, double mode : goes forward rpm nearly 1 with a lot of heat and vibrations
These were at 5v taken from the board itself. while using a 12v source, even the above motion are not observed and it becomes very hot and has too much vibrations
For my project, i need a precise number of revolutions and a decent rpm above 10-15 rpm (as max as possible).
28byj-48 stepper with adafruit motor shield v2.3
- sadikcar
Re: 28byj-48 stepper with adafruit motor shield v2.3
Stepper motors do tend to run quite warm. But it sounds like these may not be the right motors for the job. The high gear ratio requires a very high step rate. The V2 motor shield can tweaked to do up to about 1161 steps/second with some modifications to library and an increase of the i2c clock speed.
viewtopic.php?f=31&t=57041&p=292119
At 4096 steps/revolution, that works out to about 17 RPM with one motor. Half that for 2.
The other issue is that the exact gear ratios on these motors vary somewhat depending on the supplier. I've cracked open a few of them and the ratio is not quite exactly 16:1
viewtopic.php?f=31&t=41608&p=210339
- sadikcar
Thank You for the reply
So, does the motor shield support fractional no. of steps or do I have to modify the header file?
and is there a guarantee that if I get the no. of steps right then the motor will run smoothly?
It does not accept fractional steps. But at high step rates, the inter-step timing is not very precise anyway.
The rough operation could be due to wiring issues. Although they can be run as unipolar motors, they typically perform better when wired for bipolar. How do you have them connected?
- sadikcar
The connections which I have made are as shown in figure
This is the code i am using while on 5v from the mega board itself.it only works during the double forward mode that too with lower rpm.
This is a test sketch for the Adafruit assembled Motor Shield for Arduino v2
It won't work with v1.x motor shields! Only for the v2's with built in PWM
control
For use with the Adafruit Motor Shield v2
----> http://www.adafruit.com/products/1438
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Adafruit_StepperMotor *myMotor = AFMS.getStepper(4096, 2);
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Stepper test!");
AFMS.begin(); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
myMotor->setSpeed(10); // 10 rpm
Serial.println("Single coil steps");
myMotor->step(1000, FORWARD, SINGLE);
delay(500);
myMotor->step(1000, BACKWARD, SINGLE);
delay(500);
Serial.println("Double coil steps");
myMotor->step(4096/2, FORWARD, DOUBLE);
delay(500);
myMotor->step(4096/2, BACKWARD, DOUBLE);
delay(500);
Serial.println("Interleave coil steps");
myMotor->step(1000, FORWARD, INTERLEAVE);
delay(500);
myMotor->step(1000, BACKWARD, INTERLEAVE);
delay(500);
Serial.println("Microstep steps");
myMotor->step(2000, FORWARD, MICROSTEP);
delay(500);
myMotor->step(2000, BACKWARD, MICROSTEP);
delay(1000);
- IMG_20161209_101319970.jpg (655.44 KiB) Viewed 1980 times
That is unipolar wiring. Disconnect the red center-tap wire from the center ground connection for bipolar wiring.
- sadikcar
Thanks for the reply,
the motor is working smoothly now. but, it can only manage till 6 rpm, even after increasing the voltage from 5v and increasing the set speed.
also, I want to declare an array of stepper motors and shields;
While declaring a motor I am getting an error regarding expected constructor, destructor or type conversion before '=' sign.
I wonder if it is the correct syntax
Adafruit_MotorShield AFMS[5] = {Adafruit_MotorShield(0x60), Adafruit_MotorShield(0x61), Adafruit_MotorShield(0x62), Adafruit_MotorShield(0x63), Adafruit_MotorShield(0x64)};
//all the motors
const int r=4076
Adafruit_StepperMotor *abmotor[10];
*abmotor[0] = AFMS[0].getStepper(r, 1);
Which of those lines is it complaining about?
Please post the exact error text.
- sadikcar
the error lines are:
ab1:12: error: expected constructor, destructor, or type conversion before '=' token
here line 12: *abmotor[0] = AFMS[0].getStepper(r, 1);
#include <Wire.h>
//all the motors
Adafruit_StepperMotor *abmotor[10]={};
See this thread on the topic: viewtopic.php?f=31&t=96580&p=484379
- sadikcar
Thanks a lot, Sir,
the code now compiles like a breeze
just 1 more issue that is the motor still does not rotates in reverse.
If it is a motor you purchased from us, we can try replacing it. Please contact [email protected] with a link to this thread and your order information.
- sadikcar
nope, i did not purchase the motors from you guys. so, I will figure out another way
I have encountered another problem.
this is a function defined globally
and as suggested I have initialised the motors in the setup
I got an error as:
ab1.ino: In function 'void abreset(int (*)[10])':
ab1:310: error: 'abmotor' was not declared in this scope
which is a normal out of scope error. but, now I am in a fix as I can't declare the motors as global and I am also unable to insert them in a suitable function
void abreset(int abr[5][10])
int i,j;
for(i=0;i<10;i++)
for(j=1;j<5;j++);
if(abr[0][i]==1)
//servo[i] -60 deg
abr[0][i]=0;
if(abr[j][i]==1)
abmotor[i]->step(4076, FORWARD, DOUBLE); // FWD
abr[j][i]=0;
// put your setup code here, to run once:
Serial.begin(9600);
Serial.setTimeout(60000);
*abmotor[0]=AFMS[0].getStepper(r, 1);
*abmotor[1]=AFMS[0].getStepper(r, 2);
*abmotor[2]=AFMS[1].getStepper(r, 1);
*abmotor[3]=AFMS[1].getStepper(r, 2);
*abmotor[4]=AFMS[2].getStepper(r, 1);
*abmotor[5]=AFMS[2].getStepper(r, 2);
*abmotor[6]=AFMS[3].getStepper(r, 1);
*abmotor[7]=AFMS[3].getStepper(r, 2);
*abmotor[8]=AFMS[4].getStepper(r, 1);
*abmotor[9]=AFMS[4].getStepper(r, 2);
AFMS[0].begin();
AFMS[1].begin();
AFMS[2].begin();
AFMS[3].begin();
AFMS[4].begin();
Hmmm. Is abmotor declared before abreset in your code?
- sadikcar
nope, it isn't.
