I folled the instruction in the tutorial: https://learn.adafruit.com/adafruit-ult ... d?view=all
solded all pins and used an USB to plug the uno bord to the PC, uploaded the sample code but the GPS shield didn't light up any LEDs or parsed any data to the seriel monitor.
After some search and trying, i noticed that the gps shield is working if i connect the VIN pin to the 5v pin and not with the VIN to VIN connection. How can i use the shield without an extra cable ?
With best regards,
Jaki
Arduino uno with ultimate gps logger shield
- adafruit_support_carter
Re: Arduino uno with ultimate gps logger shield
Could you please post a photo showing the under side of those same pins.
- IjakiI
hmm I soldered them wrong -.- .. but if i use jumpercable it doesn't solve the problem. Here the pictures it only works with 5v connected to vin
Unfortunately, yes. I was suspicious of this when I saw the long header leads coming up through the shield in your original photos. The short leads will not make good contact into the headers on the UNO. The only way to remedy it is to flip them around - a tricky but doable resolder job.hmm I soldered them wrong
I'd suggest staying away from Vin on the UNO. It accesses the raw input power. Instead, use the 5V pin. Use your jumpers and connect that to 5V on the shield: UNO 5V -> Shield 5V. Report back.
- IjakiI
OK 5V to 5V does the job, i'll resolder everything and then the 5v uno should have connection to the 5v Shield pin and it hopefully work without jumper cables.
Thanks for the Help :D
Cool. If you can manage to get those headers flipped around, it should all just work. Good luck.
