ADS 1115 PGA
- Dirae
ADS 1115 PGA
How can someone use the Programmable Gain Amplifier setting to determine the value of a bit of ADS 1115.
Re: ADS 1115 PGA
Table 3 of the data sheet shows the full-scale range for each gain setting: https://cdn-shop.adafruit.com/datasheets/ads1115.pdf
A one lsb change in the reading would correspond to the full scale voltage divided by 2^15. (32768)
- Dirae
Re: ADS 1115 PGA
If the PGA setting = 1 or 2 or 4 or 8 or 16, and supply voltage VDD is larger than 4V, what is the maximum voltage the analog input can measure?
Re: ADS 1115 PGA
For those gain values, it can measure up to the full scale value from table 3 - or up to VDD + 0.3v whichever is smaller. As the warning states, v.Voltages more than VDD + 0.3v will damage the chip.
- Dirae
Re: ADS 1115 PGA
Thanks for your reply.
If i got you right, it means if PGA setting = 2, FS = ±2.048V and VDD = 5V, it means analog input can not measure beyond 2.048V. Am i right?
Re: ADS 1115 PGA
That is correct.
