how to use 2 adafruit shields on one arduino.
- mayur_yadav
I am trying to make a 3 axis cnc mill. for that i need 3 steppers to run at the same time and a single shield supports a maximum of 2 steppers. so is there any way of using 2 motor shields at the same time. i am using motor shield v 1.0 .
Re: how to use 2 adafruit shields on one arduino.
No. Not with the 1.0 shield. The V2 shield supports stacking.is there any way of using 2 motor shields at the same time. i am using motor shield v 1.0 .
https://learn.adafruit.com/adafruit-mot ... ng-shields
- adafruit_support_rick
The short answer is no, you can't run two of them.
The long answer is... maybe. You would have to cut traces and jumper the control pins on the second one to unused pins, and you would have to modify the AFMotor library to support the alternate set of pins.
You'd be better off with the Motor Shield V2, which is controlled via I2C, and you can easily stack them.
- mayur_yadav
actually the v2.0 shields costs around 6 times the cost of v1.0 shields and i wanted my project to be under budget.adafruit_support_rick wrote:The short answer is no, you can't run two of them.
also the v1.0 are easily available near me so i decided to use that.
can you confirm the method mentioned on the blog (link below) if it will work or not.
please !!
http://blog.workingsi.com/2011/03/metho ... -from.html
We discontinued manufacturing the V1 shield several years ago. There are numerous copies out there based on the original schematics. The tutorial you linked appears to be using genuine Adafruit boards, so if your shields are faithful to the original design, then it will probably work.
- mayur_yadav
Thank you so much for your time !adafruit_support_bill wrote:We discontinued manufacturing the V1 shield several years ago. There are numerous copies out there based on the original schematics. The tutorial you linked appears to be using genuine Adafruit boards, so if your shields are faithful to the original design, then it will probably work.
