I'm looking at the shield Eagle PCB board schematic for the GPS/logger shield. Parallel to each of the shield header rows is another row to which traces are indicated EXCEPT for the 3 GND cconnections. So, I have two questions: 1) are there really no traces between the header GND and the corresponding prototype area hole and 2) if 1) is true, how do you effect a ground in the prototyping area?
TNX
GPS/Data logger prototyping area
- Franklin97355
Re: GPS/Data logger prototyping area
It looks like the ground on the digital side is not connected but the two on the power side are.
- Attachments
- 2017-08-20_13h31_39.png (3.76 KiB) Viewed 315 times
- sjemmett
Tnx. I'll check the reverse side (forgot that :( ). I can understand the NC on the digital side.
- sjemmett
So I just took a look at all the layers in the Eagle board definition on Github. I'm not seeing any traces to any of the grounds. See the picture below. Any ideas?
- Franklin97355
Well the picture on my post comes from the Eagle brd file in the github files.
- adafruit2
there's a ground plane, you cannot see it without collpsing the plane. you can always use a multimeter to verify connections!
- sjemmett
Franklin. When I go to github, all i see is a board and schematic from about two years ago. Did you find something newer?
- sjemmett
Adafruit
I would do a continuity test but I don't yet have the shield. I'll see if there is something else in Eagle I can do to see the ground plane. Tnx
- adafruit_support_carter
Hit the "Ratsnest" button.I'll see if there is something else in Eagle I can do to see the ground plane.
