Adafruit WINC1500 WiFi Shield - memory?
by wellsa on Thu Nov 30, 2017 11:25 am
If I used this shield on my Arduino Uno, with the libraries referenced in the tutorial (https://learn.adafruit.com/adafruit-win ... o?view=all) installed, how much memory would be available for my code?
wellsa
Re: Adafruit WINC1500 WiFi Shield - memory?
by franklin97355 on Thu Nov 30, 2017 4:35 pm
If you write the code and compile the IDE will tell you.
franklin97355
by pdh on Thu Nov 30, 2017 8:01 pm
I have the ATWINC1500 breakout rather than the shield, but for whatever it's worth... when I compile the simple little sketch that checks the firmware version and displays it to Serial output, the IDE says the sketch uses 22240 (68%) of the 32 KB program space, and 1073 bytes (52%) of the 2 KB for variables. The setup() function in this sketch does all the work and is about 50 lines long, so undoubtedly the sketch itself is responsible for some of the memory usage.
pdh
by wellsa on Fri Dec 01, 2017 10:42 am
I don't want to buy the product only to find I don't have enough memory!
Has anyone followed the tutorial I referred to, and if so, how much memory is left?
That way I can gauge if my project will fit!!
Thanks.
wellsa
by pdh on Fri Dec 01, 2017 10:46 am
As Franklin said, you can compile it yourself and check. You don't need the shield in order to compile the code, so you can just write whatever you want, include the necessary libraries, and see what the IDE tells you about memory usage. You can do all that without buying the shield.
pdh
by wellsa on Sat Dec 02, 2017 4:51 pm
Ah, I see what you mean now! Thanks.
wellsa
