atwinc1500 shield on DUE
by jdelcamp11 on Mon Dec 11, 2017 6:44 pm
Does the atwinC1500 work on the DUE?
I want to upgrade my cc3000 to the new atwinc1500.
I have tested with the breakout version, but it does not seem to work.
It works fine on my uno.
I have do it wired thru the SPI header (not 11,12,13).
no errors, no leds - just hangs at "if (WiFi.status() == WL_NO_SHIELD) "
It may be a problem in the library not supporting the DUE.
jdelcamp11
Re: atwinc1500 shield on DUE
by jdelcamp11 on Wed Dec 27, 2017 12:34 pm
Update:
If I comment out the wifi status segment, I can get the check firmware sketch to work.
It reports version 19.5.2
library requires version 19.5.4
When I check the wifi101 firmware update 19.5.2 is the latest one available.
Does anyone have adafruits winc1500 shields working on a DUE?
jdelcamp11
by jdelcamp11 on Wed Jan 10, 2018 10:16 pm
Was able to update the tools. Updated to latest library 1/3/18.
Still the only example that works is the check firmware.
I have given it its own LM1117 800 mA. So it isn't a power issue.
Can someone at Adafruit confirm if the winc1500 will work on a DUE?
I don't want to purchase the shield if it isn't compatible.
jdelcamp11
by pbruno on Tue Feb 06, 2018 1:44 am
It does not work for me either. Same board works on MEGA. Hangs on WiFi.status() on the Due.
We need adafruit's feedback on this one.
pbruno
by pbruno on Thu Mar 01, 2018 7:21 pm
There was a problem with the library, which was supposedly fixed. But I am still having no luck. Works on MEGA, but DUE seems to be stuck.
Can adafruit confirm?
pbruno
by jdelcamp11 on Thu Mar 01, 2018 11:25 pm
Mine is working now on my DUE. But only if I declare the pins
//*These are the selectable interrupt and control pins for the Winc1500
#define wifi_IRQ    7  // MUST be an interrupt pin!
#define wifi_Reset  5  // These 2 can be any two pins
#define wifi_CS    10
  // Use hardware SPI for the remaining pins
  // On an UNO, SCK = 13, MISO = 12, and MOSI = 11 */
int status = WL_IDLE_STATUS;
void setup()
  WiFi.setPins(wifi_CS,wifi_IRQ,wifi_Reset);
jdelcamp11
by pbruno on Thu Mar 01, 2018 11:37 pm
I apologize... I had the .setPins incorrectly. As it turns out, you do not need to declare these on Due (or MEGA) as they are the defaults in the library.
pbruno
cron
