Standalone AVR Chip Programmer - Upload code on Arduino V1.0
by rossco_s on Sat Dec 16, 2017 2:45 am
I have a Standalone AVR Chip Programmer thats been sitting in my parts box for some time and I want to use it to burn some bootloaders.
If I use it as specified in the ArduinoISP, it works, but I want it to be standalone.
When following the Standalone guide, if I try compiling the AdaLoader sketch in Arduino version 1.8.5 I get the following:
/root/Arduino/AdaLoader/AdaLoader.ino: In function 'void loop()':
/root/Arduino/AdaLoader/AdaLoader.ino:82:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     error("Signature fail");
/root/Arduino/AdaLoader/AdaLoader.ino:84:23: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     error("Image fail");
/root/Arduino/AdaLoader/AdaLoader.ino:89:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     error("Programming Fuses fail");
/root/Arduino/AdaLoader/AdaLoader.ino:92:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     error("Failed to verify fuses");
/root/Arduino/AdaLoader/AdaLoader.ino:113:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    error("Flash programming failed");
/root/Arduino/AdaLoader/AdaLoader.ino:121:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/root/Arduino/AdaLoader/AdaLoader.ino:128:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     error("Failed to verify chip");
/root/Arduino/AdaLoader/AdaLoader.ino:134:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/tmp/ccTbQny2.ltrans0.ltrans.o: In function `start_pmode()':
/root/Arduino/AdaLoader/AdaLoader.ino:170: undefined reference to `spi_transaction(unsigned char, unsigned char, unsigned char, unsigned char)'
/tmp/ccTbQny2.ltrans0.ltrans.o: In function `setup':
/root/Arduino/AdaLoader/AdaLoader.ino:51: undefined reference to `pulse(int, int)'
/root/Arduino/AdaLoader/AdaLoader.ino:53: undefined reference to `pulse(int, int)'
/tmp/ccTbQny2.ltrans0.ltrans.o: In function `loop':
/root/Arduino/AdaLoader/AdaLoader.ino:81: undefined reference to `readSignature()'
/root/Arduino/AdaLoader/AdaLoader.ino:83: undefined reference to `findImage(unsigned int)'
/root/Arduino/AdaLoader/AdaLoader.ino:86: undefined reference to `eraseChip()'
/root/Arduino/AdaLoader/AdaLoader.ino:88: undefined reference to `programFuses(unsigned char const*)'
/root/Arduino/AdaLoader/AdaLoader.ino:91: undefined reference to `verifyFuses(unsigned char const*, unsigned char const*)'
/root/Arduino/AdaLoader/AdaLoader.ino:105: undefined reference to `readImagePage(unsigned char*, unsigned int, unsigned char, unsigned char*)'
/root/Arduino/AdaLoader/AdaLoader.ino:112: undefined reference to `flashPage(unsigned char*, unsigned int, unsigned char)'
/root/Arduino/AdaLoader/AdaLoader.ino:120: undefined reference to `programFuses(unsigned char const*)'
/root/Arduino/AdaLoader/AdaLoader.ino:127: undefined reference to `verifyImage(unsigned char*)'
/root/Arduino/AdaLoader/AdaLoader.ino:133: undefined reference to `verifyFuses(unsigned char const*, unsigned char const*)'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Duemilanove or Diecimila.
If I try using Arduino 1.0 or Arduino 0023 I get the following message:
./arduino: 22: ./arduino: java: not found
Which is weird because I don't have arduino 0022.
rossco_s
Re: Standalone AVR Chip Programmer - Upload code on Arduino
by rossco_s on Sun Dec 17, 2017 2:51 pm
Can anyone help me with this problem?
rossco_s
by franklin97355 on Sun Dec 17, 2017 9:46 pm
Can you post some pictures of the programmer and its connections?
franklin97355
by rossco_s on Wed Dec 20, 2017 2:30 am
Here is a photo.
It worked last time I used it, although that was quite some time ago.
The problem seems to be with the software side of things.
rossco_s
by rossco_s on Fri Dec 22, 2017 2:20 am
I just tried installing Arduino using apt-get package manager in Ubuntu. I still got some minor compile errors:
images.cpp:3:17: error: variable ‘image_328’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
 image_t PROGMEM image_328 = {
When I made image_t a const it compiled.
Would I be correct to assume that if I upload the code to a Uno and use the https://learn.adafruit.com/standalone-avr-chip-programmer/assembly to program the bootloader that I would then be burning Uno bootloaders?
I have a sneaking suspicion that since the Optiloader code is quite old ( ~5 years) that it may well be a Duemilanove. Would that be unfounded?
rossco_s
by rossco_s on Fri Dec 22, 2017 2:28 am
I just tried burning the bootloader onto a fresh ATmega328P-PU. I double checked the orientation, locked the chip in and pressed the button.
The red LED immediately came on and the buzzer sounded continuously. I had to unplug the Arduino to stop the buzzer.
I'm not sure how to proceed now. It would be great if an Adafruit moderator could chime in.
rossco_s
