Hi. I am pretty new in C++ programming and it seems the issue I am facing is beyond me. I have attached Adafruit 808 shield to my Arduino Uno and I am trying to run the below sketch using 115200baud rate.
// Libraries
#include "Adafruit_FONA.h"
#include <SoftwareSerial.h>
// Pins
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// Buffer
char replybuffer[255];
// Instances
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
//HardwareSerial *fonaSerial = &Serial;
// Use this for FONA 800 and 808s
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
//Use this one for FONA 3G
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
// Init board
while (!Serial);
Serial.begin(115200);
Serial.println(F("FONA location test"));
Serial.println(F("Initializing....(May take 3 seconds)"));
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
Despite the compilation is fine, I am getting the following message in serial monitor:
FONA location test
Attempting to open comm with ATs
---> AT
---> AT
---> AT
---> AT
Timeout: No response to AT... last ditch attempt.
---> AT
---> AT
---> AT
---> ATE0
---> ATE0
Couldn't find FONA
The lipo battery, GSM ANT, AND GPS are connected accordingly. The led is blinking in blue and everything looks fine, however fona cannot be found whatsoever. Can someone help me out to put it right?
Problem with Arduino Adafruit 808 shield
- jarek76
Re: Problem with Arduino Adafruit 808 shield
Doea anybody know the answer?
- katrinasiegfried
Do you have a LiPo battery plugged into the JST connector? You cannot use the FONA without one.
- jarek76
Yes, lipo battery is connected accordingly.
- adafruit_support_carter
Post a photo of your setup showing all connections.
- jarek76
There you go...
- pic4.jpg (264.44 KiB) Viewed 411 times
- pic3.jpg (265.59 KiB) Viewed 411 times
- pic1.jpg (199.88 KiB) Viewed 411 times
You need to solder on the headers:
https://learn.adafruit.com/adafruit-fon ... ing-header
- jarek76
Many thanks. It works now, however the following error pops up:
---> AT+CGNSPWR?
<--- +CGNSPWR: 0
---> AT+CGNSPWR=1
<--- OK
---> AT+CIPSHUT
<--- SHUT OK
---> AT+CGATT=1
<--- ERROR
---> AT+CGNSINF
<--- +CGNSINF: 0,,,,,,,,,,,,,,,,,,,,
Localisation method: GPRS
---> AT+CIPGSMLOC=1,1
<--- +CIPGSMLOC: 601
Fail code #601
Does it mean there is something wrong with my sim card?
---> AT+CGNSPWR?
<--- +CGNSPWR: 0
---> AT+CGNSPWR=1
<--- OK
---> AT+CIPSHUT
<--- SHUT OK
---> AT+CGATT=1
<--- ERROR
---> AT+CGNSINF
Fail code #601
What example sketch are trying to run?
- jarek76
I am trying to run a standard Fona test sketch. Have also tried to enable GPRS via "G" command, however to no avail. The following message is being populated:
SHUT OFONA> K
G
---> AT+CIPSHUT
<--- AT+CIPSHUT
---> AT+CGATT=1
<--- AT+CGATT=1
Failed to turn on
OK
FONA>
Raw NMEA out attached below:
FONA>
Call Ready
SMS Ready
L
---> AT+CGNSINF
Reply in format: mode,fixstatus,utctime(yyyymmddHHMMSS),latitude,longitude,altitude,speed,course,fixmode,reserved1,HDOP,PDOP,VDOP,reserved2,view_satellites,used_satellites,reserved3,C/N0max,HPA,VPA
FONA> t
---> AT+CCLK?
<--- +CCLK: "04/01/01,00:56:04+00"
Time = "04/01/01,00:56:04+00"
FONA> G
---> AT+CIPSHUT
<--- SHUT OK
---> AT+CGATT=1
<--- OK
---> AT+SAPBR=3,1,"CONTYPE","GPRS"
<--- OK
---> AT+SAPBR=3,1,"APN","FONAnet"
<--- OK
---> AT+CSTT="FONAnet"
<--- OK
---> AT+SAPBR=1,1
<--- ERROR
Failed to turn on
FONA>
SHUT OFONA> K
G
---> AT+CIPSHUT
<--- AT+CIPSHUT
---> AT+CGATT=1
<--- AT+CGATT=1
Failed to turn on
OK
FONA>
FONA>
Call Ready
SMS Ready
L
---> AT+CGNSINF
FONA> t
---> AT+CCLK?
FONA> G
---> AT+CIPSHUT
<--- SHUT OK
---> AT+CGATT=1
<--- OK
<--- OK
<--- OK
<--- OK
---> AT+SAPBR=1,1
<--- ERROR
Failed to turn on
FONA>
