I received my order for a Winc1500 WiFi shield (253274851104) about two weeks ago. After installing headers I tested the device with an Arduino Mega using IDE version 1.8.5. I used the library WiFi101.h as suggested in the literature. The shield appeared to work with Examples/Wifi101/WiFiSSLClient using my SSID and Password. It reported "Connected to wifi" but it did not seem to be able to connect to my server by using the command "client.connect(server, 80)" . I tried again with a brand new Mega with the same result. I consulted various forums and was advised to check the firmware. This I did with the WiFi101 example sketch "CheckWiFi101firmwareVersion. The sketch gave the result "NOT PASSED" with the warning "The firmware version on the shield does not match the version required by the library, you may experience issues or failures."
I attempted to update the firmware using the tool WiFi101 Firmware Updater. It appeared to work; on pressing the "Test Connection" button it reported "The programmer is working" (pic 1) but when I pressed the "Update Firmware" button it went about half way through and stopped with the message "Error while writing flash memory" (Pic 2). I tried several times then tried other Mega boards and even tried with an Uno board.
I can progress no further. Since the unsuccessful firmware update the shield is no longer recognised in sketches that previously worked with it (Pic 3). I can do no more testing. I need a new shield; preferably one which has the firmware already updated.
Here are the screen grabs illustrating my problems.
Cannot update firmware new Winc1500 WiFi shield
- bcoulter40
- Attachments
- WiFi programmer1.jpg (41.52 KiB) Viewed 675 times
- WiFi programmer2.jpg (41.17 KiB) Viewed 675 times
- CheckWiFi101FirmwareVersion.JPG (116.72 KiB) Viewed 675 times
- adafruit_support_carter
Re: Cannot update firmware new Winc1500 WiFi shield
Hello. Sorry for the delay in responding.
Could you please post a photo of your setup showing how your are using the shield.I tried several times then tried other Mega boards and even tried with an Uno board.
- adafruit2
you dont by chance have an arduino zero or m0 do you? thats the chipset this shield is most-used-with
- bcoulter40
I don't have a zero to try it with. However it appeared to be functioning until I followed its advice to update the firmware and that stopped halfway with a notice that there was an error with flash memory. After that it had been "bricked".
- bcoulter40
I tested the board with both Uno and Mega boards in the absence of any other circuitry. There seems to be a problem with the Winc1500 in that the firmware updating stopped with the message "Error while writing flash memory". Anyway, here is a picture as requested.adafruit2 wrote:you dont by chance have an arduino zero or m0 do you? thats the chipset this shield is most-used-with
- Attachments
- Winc1500.jpg (141.32 KiB) Viewed 514 times
- adafruit2
ok not sure what happened! soldering looks good, but we can replace it. email support@adafruit and ask for a new shield :)
