Software volume control
stoopid_jerk
Post by stoopid_jerk »
Hi there,
recently put together my Waveshield, thanks for this great kit and the clear instructions for assembly and great libraries and examples and lots of information here on this forum. Everything worked out of the box for me, which i didn't really expect would happen but ok thats great.
I want to do software volume control, un#defined the DVOLUME const in the AF_Wave library and that worked. But i get a popping noise when i change the volume. I tried with WaveHC as well, which required a bit more hacking than just the #define in AF_Wave, but with the same results. Have others experienced this as well, or maybe i've done something wrong? If this is expected, any tips on how to eliminate this popping?
thanks in advance
dave
Re: Software volume control
Post by adafruit »
the volume control is kinda iffy. and if you change the volume quickly you'll make a square wvae. so adjust it -slooowly- :)
rafaelvc
Post by rafaelvc »
Hi there,
I am a new Arduino and Waveshield user and I know It has been a while since the last reply in this post, but I would like to know how to use volume control with WaveHC.
I tried "SoftVolumeHC", an example that came with WaveHC, but it wont compile in any way. This is what I get as error messages:
'class WaveHC has no member named volume'
SoftVolumeHC.cpp: In function 'void playcomplete(FatReader&)':
SoftVolumeHC:109: error: 'class WaveHC' has no member named 'volume'
SoftVolumeHC:112: error: 'class WaveHC' has no member named 'volume'
SoftVolumeHC:113: error: 'class WaveHC' has no member named 'volume'
SoftVolumeHC:114: error: 'class WaveHC' has no member named 'volume'
If somebody has any clue about it, I'd be very glad to hear it.
Thanks in advance,
Rafael Vasconcelos
mtague
Post by mtague »
It compiles if you change DVOLUME to nonzero in the WaveHC.h file (from zero to one, for example). This step is in the comment right above the line that the compiler has an issue with, near the bottom of the sketch:
    // DVOLUME must be nonzero in WaveHC.h to use volume.
    Serial.println(wave.volume, DEC);
    delay(2000);
    wave.volume++;
    if ( wave.volume == 12) {
      wave.volume = 0;
  sdErrorCheck();
Reading the comments in the sketch is a good thing to do when you're a noob (finding this out myself, as I'm also a noob). :D
rafaelvc
Post by rafaelvc »
thanks, mtague, for the help. It is working now very nicely.
Yes, you're right about reading the comments. But I am quite sure I read it, but of course I missed it. I'll pay more attention next time.
Thanks again. Best regards,
Rafael Vasconcelos
mtague
Post by mtague »
I was actually having the exact same problem you were, but reading your post made me recheck the code again and I found that sneaky little code comment. :D
maurin
Post by maurin »
I'm trying to use wave.volume but each time I change the value I get a clic :?
maurin
Post by maurin »
Below the code i use, I added a fadeIn fadeOut fonction.
The delay between each wave.volume changes is set @ 500 millis but I still have those clic.
Is ther a way to avoid it ?
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;       // This object holds the information for the card
FatVolume vol;       // This holds the information for the partition on the card
FatReader root;      // This holds the information for the filesystem on the card
FatReader file;       // This holds the information for the file we're play
WaveHC wave;         // This is the only wave (audio) object...
# define THRESHOLD      250              // define threshold
# define fadeTime       500                 // define fade time
boolean rising = false;
boolean fade = false;                        // set the fade direction IN - OUT
boolean DEBUG = true;
unsigned int reading = 0;
unsigned int fadeValue = 12;               // hold fade value
unsigned long lastTime = 0;                 // hold time value
unsigned int volume = 0;                     // hold volume value
void setup(){
  Serial.begin(9600);   // set up serial port
  putstring_nl("WaveHC IR sensor");
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);    // SLAVESELECT
  pinMode(3, OUTPUT);    // CLOCK
  pinMode(4, OUTPUT);    // DATA
  pinMode(5, OUTPUT);    // GND
  pinMode(13, OUTPUT);   // LED pin also SCK pin for (ISP)
  if(!card.init()) {                     // play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    while(1);                            // then 'halt' - do nothing!
  card.partialBlockRead(true);  // enable optimize read
  // Now we will look for a FAT partition!
  uint8_t part;
  for(part = 0; part < 5; part++) {      // we have up to 5 slots to look in
    if(vol.init(card, part))
      break;                             // we found one, lets bail
  if(part == 5) {                        // if we ended up not finding one  :(
    putstring_nl("No valid FAT!");
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);      // FAT16 or FAT32?
  // Try to open the root directory
  if(!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  putstring_nl("Ready!");                 // Whew! We got past the tough parts.
void loop(){
  reading = analogRead(A0);
  if(reading < THRESHOLD && rising == true){
    if(DEBUG)Serial.println("OFF");
    rising = false;
  if(reading > THRESHOLD && rising == false){
    if(DEBUG)Serial.println("ON");
    rising = true;
    playfile("LOOP.WAV");
  wave.volume = fadeInOut(fadeTime, rising, fadeValue);
void playfile(char *name){
  // see if the wave object is currently doing something
  if(wave.isplaying) {  // already playing something, so stop it!
    wave.stop();        // stop it
  // look in the root directory and open the file
  if(!file.open(root, name)) {
    putstring("Couldn't open file");
    Serial.print(name);
    return;
  // OK read the file and turn it into a wave object
  if(!wave.create(file)){
    putstring_nl("Not a valid WAV");
    return;
  wave.play();   // ok time to play! start playback
unsigned int fadeInOut(const int del, boolean fade, unsigned int &fadeVal){
  if(fade == true){ // fade IN
    if(fadeVal < 1) return 0;
    if((millis() - lastTime) > del){
      fadeVal--;
      lastTime = millis();
      if(DEBUG)Serial.println(fadeVal, DEC);
      return fadeVal;
  if(fade == false){ // fade OUT
    if(fadeVal > 11) return 12;
      fadeVal++;
      return fadeVal;
Anytime you have a step-change in the output level there will be a click. The best you can do is to keep the step levels as small as possible.
fat16lib
Post by fat16lib »
The volume steps in WaveHC are large so there are clicks.
I worked with an artist to develop a player with finer volume control based on my other audio library, WaveRP.
It is limited to 22.05 ksps files due to the overhead of finer volume control and is very experimental.
It tries to do one db steps in volume.
You need to install the latest version of SdFat to use it.
http://code.google.com/p/sdfatlib/downloads/list
I have attached the library.
See the readme file and try the sketch, dapRPvol.pde.
dbPerStep.zip
(14.06 KiB) Downloaded 149 times
EddieVerso
Post by EddieVerso »
Hi man, I'm trying this library but, after the installation, I can't compile due to this error:
'Class WaveRP' has no member named 'setVolume'
DBperStep.cpp: In function 'void play(SdBaseFile*)':
DBperStep:104: error: 'class WaveRP' has no member named 'setVolume'
DBperStep:116: error: 'class WaveRP' has no member named 'setVolume'
Thanks man, I hope this library will solve my volume changing problems :)
EddieVerso
Sorry, i forgot to set DVOLUME 1 in the library, my fault :D
Anyway now it works well, tnx for the library!
