Hi all,
I have an OrangePi Lite(same like Raspberry Model A, B), and a DK Electronics Motor shield(https://cdn-learn.adafruit.com/download ... shield.pdf).
I use C# .NET Core, on my Orange Pi, with Armbian operation system, and WiringPi library to handle GPIO ports. I tried several examples from the internet like this: http://blog.janlipovsky.cz/2016/03/robo ... 2.html?m=1
but it was not success, I can't control my DC motor. I followed the cable connections between OrangePi and Motor Shield from the previous example, the green led lights on the shield, I translated his python source code to C#, but the motor do nothing. I tried to give direct voltage for motor shield, and tried the OrangePi power too, I switched the modes with PWR jumper.
I tested the motor directly with 5 voltage, that works. I used the gpio with leds, that works too.
I will very thankful for every help(links, C# code examples, others)
Thank you!
Control DC motor AF motor shield, OrangePi
Re: Control DC motor AF motor shield, OrangePi
These are not products we sell or support at Adafruit. You should be able to get technical assistance from the manufacturer of your boards.I have an OrangePi Lite(same like Raspberry Model A, B), and a DK Electronics Motor shield
