2.8 Inch TFT LCD Shield Touch Panel Module
by ril5156 on Fri Apr 13, 2018 2:57 pm
I am using the 2.8 Inch TFT LCD Shield Touch Panel Module (Version 3), I was able to figure it's ID (0x8230). But I am still not able to make it work with it's standard libraries (Adafruit_TFTLCD.h and Adafruit_GFX.h).
Using the example graphicstest from the example folder, all im getting is the following:
TFT LCD test
Using Adafruit 2.8" TFT Arduino Shield Pinout
TFT size is 240x320
Unknown LCD driver chip: 8230
If using the Adafruit 2.8" TFT Arduino shield, the line:
#define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
Once I follow the intructions from the Serial Monitor I get the same result but with a different driver chip:
Unknown LCD driver chip: 101
Any advice???
ril5156
Re: 2.8 Inch TFT LCD Shield Touch Panel Module
by slowpoke57 on Thu Aug 15, 2019 8:14 pm
Hi, try using MCUFRIEND_kbv files.
MCUFRIEND_kbv-master.zip
(874.46 KiB) Downloaded 20 times
slowpoke57
