I am trying to get the connection details using Arduino & Adafruit CC3000. But my code gets stuck on checkDHCP() method. I have also tried to set a static IP address, and then setDHCP again to enable it. (The setup() function is from the Adafruit Library HTTPServer sketch)Here is my setup function:
void setup(void)
Serial.begin(115200);
pinMode(ldrPin, INPUT);
Serial.println(F("Hello, CC3000!\n"));
Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
// Initialise the module
Serial.println(F("\nInitializing..."));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
Serial.print(F("\nAttempting to connect to ")); Serial.println(WLAN_SSID);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("Failed!"));
while(1);
Serial.println(F("Connected!"));
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100); // ToDo: Insert a DHCP timeout!
// Display the IP address DNS, Gateway, etc.
while (! displayConnectionDetails()) {
delay(1000);
// Start listening for connections
httpServer.begin();
Serial.println(F("Listening for connections..."));
