Timing issue between two CAN message
by dutta_gaurav on Wed Jun 27, 2018 11:56 am
So i am using two CAN shield stacked on one another. i am trying to receive the same message with the same identifier but on different CAN networks. I want to receive both of them together, compare and print the difference.
The problem i am facing is both the can messages are received at different times so at one point of time it shows the difference while other time it receives a 0 from the other can message and shows a difference of negative the first value (Voltage1-voltage2).
there is a timing issue. how do i solve this so i i keep the previous value and only compare when both the messages have been received?
Thank you again.
#include <mcp_can.h>
#include <SPI.h>
static int Voltage1;
static int Voltage2;
const int SPI_CS_PIN1 = 9; // select pin 9
const int SPI_CS_PIN2 = 10 ; // select pin 10
MCP_CAN CAN1 (SPI_CS_PIN1);
MCP_CAN CAN2 (SPI_CS_PIN2);                                     // Set CS pin
void setup()
    Serial.begin(9600);
   if (CAN_OK != CAN1.begin(CAN_500KBPS) && CAN_OK != CAN2.begin(CAN_500KBPS) )              // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init fail");
        Serial.println(" Init CAN BUS Shield again");
        delay(100);
    Serial.println("CAN BUS Shield init ok!");
unsigned char data3[8] = {04,00,00,00,00,00,00,00}; // Wake up can
void loop()
    unsigned char len1 = 0;// clear flag  unsigned char len1 = 0;
    unsigned char buf1[8];
    unsigned char len2 = 0;
    unsigned char buf2[8];
    CAN1.sendMsgBuf(0x700,0,8,data3); // Send pack 1 to communicate
    CAN2.sendMsgBuf(0x700,0,8,data3); // Send pack 2 to communicate
    if(CAN_MSGAVAIL == CAN1.checkReceive())         // check if data coming
       CAN1.readMsgBuf(&len1, buf1);
       unsigned int canId1 = CAN1.getCanId();
      if (canId1==768)
                    unsigned int x1= buf1[2]; //Select bit
                    unsigned int y1= buf1[3];
                    unsigned int z1= x1*256 + y1; //concatenate
                    Voltage1 = z1*0.002; //Convert obtained decimal value to voltage
                    Serial.println(Voltage1);
      if(CAN_MSGAVAIL == CAN2.checkReceive())
          CAN2.readMsgBuf(&len2, buf2);
          unsigned int canId2 = CAN2.getCanId();
      if (canId2==768)
                    unsigned int x2= buf2[2]; //Select bit
                    unsigned int y2= buf2[3];
                    unsigned int z2= x2*256 + y2; //concatenate
                    Voltage2 = z2*0.002; //Convert obtained decimal value to voltage
                    Serial.println(Voltage2);
       int difference=Voltage1-Voltage2;
      Serial.println(difference);
dutta_gaurav
Re: Timing issue between two CAN message
by adafruit_support_bill on Wed Jun 27, 2018 12:29 pm
We do not make a CAN bus shield. You should contact the manufacturer of your shields for assistance.
