Stepper Motor speed does not go beyond 200 RPM
by BRANDONRUF on Mon Jul 02, 2018 8:02 pm
Hello community,
I am using the V2 Adafruit motor shield to power a NEMA 17 motor I purchased from McMaster. Despite maximizing the clock speed to 400 khz, and setting my code to tell the motor to run 1000 RPM, the motor is actually running at a speed of 200 RPM. Is this something to do with the motor shield hardware and/or my coding? Because according to the manufacturer's specs on the stepper motor, it can run up to 900RPM. I am using a 9V adapter as a power source for the motor and motor shield. Here is the code that I used to run the motor. Thank you for taking the time to read my forum post.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Stepper test!");
AFMS.begin(10000); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
myMotor->setSpeed(1100);
Wire.setClock(400000) ; // Change the i2c clock to 400KHz
Serial.println("Double coil steps");
myMotor->step(200*48, BACKWARD, DOUBLE);
delay(1000);
myMotor->step(200*48, FORWARD, DOUBLE);
while(1){}
BRANDONRUF
Re: Stepper Motor speed does not go beyond 200 RPM
by adafruit_support_bill on Mon Jul 02, 2018 8:20 pm
Some people have had luck increasing the clock speed as high as 1MHz.
You can also hack the library a bit to remove the microstepping overhead as described here:
viewtopic.php?f=31&t=57041&p=292119
by BRANDONRUF on Mon Jul 02, 2018 9:41 pm
By hacking the library do you mean just adding lines of code to a specific file?
BRANDONRUF
by BRANDONRUF on Mon Jul 02, 2018 10:32 pm
I followed your instructions and this is what the main code looks like now, but its not working. Is there a mistake I made?
#include <Wire.h>
  delay(1000);
  while(1){}
[u]long start = millis();
  for (int i = 0; i < 10000; i++)
    myMotor->quickstep(FORWARD);
    delayMicroseconds(325);
  Serial.println(millis() - start)[/u];
Last edited by adafruit_support_bill on Tue Jul 03, 2018 5:42 am, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums
BRANDONRUF
by adafruit_support_bill on Tue Jul 03, 2018 5:45 am
but its not working
Can you be more specific? Not compiling? Not uploading? Not turning? Not turning as fast as you would like?
by BRANDONRUF on Tue Jul 03, 2018 9:32 am
Not turning at all
BRANDONRUF
by adafruit_support_bill on Tue Jul 03, 2018 9:39 am
Please post the serial output from running your code.
by BRANDONRUF on Tue Jul 03, 2018 9:44 am
Here are the changes (hacks) I did:
(H Code)
#ifndef _Adafruit_MotorShield_h_
#define _Adafruit_MotorShield_h_
#include <inttypes.h>
#include <Wire.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
//#define MOTORDEBUG
#define MICROSTEPS 16         // 8 or 16
#define MOTOR1_A 2
#define MOTOR1_B 3
#define MOTOR2_A 1
#define MOTOR2_B 4
#define MOTOR4_A 0
#define MOTOR4_B 6
#define MOTOR3_A 5
#define MOTOR3_B 7
#define FORWARD 1
#define BACKWARD 2
#define BRAKE 3
#define RELEASE 4
#define SINGLE 1
#define DOUBLE 2
#define INTERLEAVE 3
#define MICROSTEP 4
class Adafruit_MotorShield;
/** Object that controls and keeps state for a single DC motor */
class Adafruit_DCMotor
 public:
  Adafruit_DCMotor(void);
  friend class Adafruit_MotorShield;  ///< Let MotorShield create DCMotors
  void run(uint8_t);
  void setSpeed(uint8_t);
 private:
  uint8_t PWMpin, IN1pin, IN2pin;
  Adafruit_MotorShield *MC;
  uint8_t motornum;
/** Object that controls and keeps state for a single stepper motor */
class Adafruit_StepperMotor {
 public:
  Adafruit_StepperMotor(void);
  void setSpeed(uint16_t);
  void step(uint16_t steps, uint8_t dir,  uint8_t style = SINGLE);
  uint8_t onestep(uint8_t dir, uint8_t style);
  void release(void);
  friend class Adafruit_MotorShield;  ///< Let MotorShield create StepperMotors
 private:
  uint32_t usperstep;
  uint8_t PWMApin, AIN1pin, AIN2pin;
  uint8_t PWMBpin, BIN1pin, BIN2pin;
  uint16_t revsteps; // # steps per revolution
  uint8_t currentstep;
  uint8_t steppernum;
 [u] uint8_t quickstep(uint8_t dir);[/u]
/** Object that controls and keeps state for the whole motor shield.
    Use it to create DC and Stepper motor objects! */
  public:
    Adafruit_MotorShield(uint8_t addr = 0x60);
    void begin(uint16_t freq = 1600, TwoWire *theWire = NULL);
    Adafruit_DCMotor *getMotor(uint8_t n);
    Adafruit_StepperMotor *getStepper(uint16_t steps, uint8_t n);
    friend class Adafruit_DCMotor;   ///< Let DCMotors control the Shield
    void setPWM(uint8_t pin, uint16_t val);
    void setPin(uint8_t pin, boolean val);
 private:
    TwoWire *_i2c;
    uint8_t _addr;
    uint16_t _freq;
    Adafruit_DCMotor dcmotors[4];
    Adafruit_StepperMotor steppers[2];
    Adafruit_MS_PWMServoDriver _pwm;
#endif
CPP Code
#include "Arduino.h"
#include <Wire.h>
#include "Adafruit_MotorShield.h"
#include <Adafruit_MS_PWMServoDriver.h>
#if (MICROSTEPS == 8)
///! A sinusoial microstepping curve for the PWM output (8-bit range) with 9 points - last one is start of next step.
uint8_t microstepcurve[] = {0, 50, 98, 142, 180, 212, 236, 250, 255};
#elif (MICROSTEPS == 16)
///! A sinusoial microstepping curve for the PWM output (8-bit range) with 17 points - last one is start of next step.
uint8_t microstepcurve[] = {0, 25, 50, 74, 98, 120, 141, 162, 180, 197, 212, 225, 236, 244, 250, 253, 255};
#endif
    @brief  Create the Motor Shield object at an I2C address, default is 0x60
    @param  addr Optional I2C address if you've changed it
Adafruit_MotorShield::Adafruit_MotorShield(uint8_t addr) {
  _addr = addr;
  _pwm = Adafruit_MS_PWMServoDriver(_addr);
    @brief  Initialize the I2C hardware and PWM driver, then turn off all pins.
    @param    freq
    The PWM frequency for the driver, used for speed control and microstepping.
    By default we use 1600 Hz which is a little audible but efficient.
    @param    theWire
    A pointer to an optional I2C interface. If not provided, we use Wire or Wire1
    (on Due)
void Adafruit_MotorShield::begin(uint16_t freq, TwoWire *theWire) {
  if (! theWire) {
#if defined(ARDUINO_SAM_DUE)
    _i2c = &Wire1;
#else
    _i2c = &Wire;
#endif
  } else {
    _i2c = theWire;
  // init PWM w/_freq
  _i2c->begin();
  _pwm.begin();
  _freq = freq;
  _pwm.setPWMFreq(_freq);  // This is the maximum PWM frequency
  for (uint8_t i=0; i<16; i++)
    _pwm.setPWM(i, 0, 0);
    @brief  Helper that sets the PWM output on a pin and manages 'all on or off'
    @param  pin The PWM output on the driver that we want to control (0-15)
    @param  value The 12-bit PWM value we want to set (0-4095) - 4096 is a special 'all on' value
void Adafruit_MotorShield::setPWM(uint8_t pin, uint16_t value) {
  if (value > 4095) {
    _pwm.setPWM(pin, 4096, 0);
  } else
    _pwm.setPWM(pin, 0, value);
    @brief  Helper that sets the PWM output on a pin as if it were a GPIO
    @param  value HIGH or LOW depending on the value you want!
void Adafruit_MotorShield::setPin(uint8_t pin, boolean value) {
  if (value == LOW)
    _pwm.setPWM(pin, 0, 0);
  else
    @brief  Mini factory that will return a pointer to an already-allocated
    Adafruit_DCMotor object. Initializes the DC motor and turns off all pins
    @param  num The DC motor port we want to use: 0 thru 3 are valid
    @returns NULL if something went wrong, or a pointer to a Adafruit_DCMotor
Adafruit_DCMotor *Adafruit_MotorShield::getMotor(uint8_t num) {
  if (num > 4) return NULL;
  num--;
  if (dcmotors[num].motornum == 0) {
    // not init'd yet!
    dcmotors[num].motornum = num;
    dcmotors[num].MC = this;
    uint8_t pwm, in1, in2;
    if (num == 0) {
      pwm = 8; in2 = 9; in1 = 10;
    } else if (num == 1) {
      pwm = 13; in2 = 12; in1 = 11;
    } else if (num == 2) {
      pwm = 2; in2 = 3; in1 = 4;
    } else if (num == 3) {
      pwm = 7; in2 = 6; in1 = 5;
    dcmotors[num].PWMpin = pwm;
    dcmotors[num].IN1pin = in1;
    dcmotors[num].IN2pin = in2;
  return &dcmotors[num];
    Adafruit_StepperMotor object with a given 'steps per rotation.
    Then initializes the stepper motor and turns off all pins.
    @param  steps How many steps per revolution (used for RPM calculation)
    @param  num The stepper motor port we want to use: only 0 or 1 are valid
    @returns NULL if something went wrong, or a pointer to a Adafruit_StepperMotor
Adafruit_StepperMotor *Adafruit_MotorShield::getStepper(uint16_t steps, uint8_t num) {
  if (num > 2) return NULL;
  num--;
  if (steppers[num].steppernum == 0) {
    // not init'd yet!
    steppers[num].steppernum = num;
    steppers[num].revsteps = steps;
    steppers[num].MC = this;
    uint8_t pwma, pwmb, ain1, ain2, bin1, bin2;
    if (num == 0) {
      pwma = 8; ain2 = 9; ain1 = 10;
      pwmb = 13; bin2 = 12; bin1 = 11;
      pwma = 2; ain2 = 3; ain1 = 4;
      pwmb = 7; bin2 = 6; bin1 = 5;
    steppers[num].PWMApin = pwma;
    steppers[num].PWMBpin = pwmb;
    steppers[num].AIN1pin = ain1;
    steppers[num].AIN2pin = ain2;
    steppers[num].BIN1pin = bin1;
    steppers[num].BIN2pin = bin2;
  return &steppers[num];
               MOTORS
    @brief  Create a DCMotor object, un-initialized!
    You should never call this, instead have the {@link Adafruit_MotorShield}
    give you a DCMotor object with {@link Adafruit_MotorShield.getMotor}
Adafruit_DCMotor::Adafruit_DCMotor(void) {
  MC = NULL;
  motornum = 0;
  PWMpin = IN1pin = IN2pin = 0;
    @brief  Control the DC Motor direction and action
    @param  cmd The action to perform, can be FORWARD, BACKWARD or RELEASE
void Adafruit_DCMotor::run(uint8_t cmd) {
  switch (cmd) {
  case FORWARD:
    MC->setPin(IN2pin, LOW);  // take low first to avoid 'break'
    MC->setPin(IN1pin, HIGH);
    break;
  case BACKWARD:
    MC->setPin(IN1pin, LOW);  // take low first to avoid 'break'
    MC->setPin(IN2pin, HIGH);
    break;
  case RELEASE:
    break;
    @brief  Control the DC Motor speed/throttle
    @param  speed The 8-bit PWM value, 0 is off, 255 is on
void Adafruit_DCMotor::setSpeed(uint8_t speed) {
  MC->setPWM(PWMpin, speed*16);
               STEPPERS
    @brief  Create a StepperMotor object, un-initialized!
    give you a StepperMotor object with {@link Adafruit_MotorShield.getStepper}
Adafruit_StepperMotor::Adafruit_StepperMotor(void) {
  revsteps = steppernum = currentstep = 0;
    @brief  Set the delay for the Stepper Motor speed in RPM
    @param  rpm The desired RPM, we will do our best to reach it!
void Adafruit_StepperMotor::setSpeed(uint16_t rpm) {
  //Serial.println("steps per rev: "); Serial.println(revsteps);
  //Serial.println("RPM: "); Serial.println(rpm);
  usperstep = 60000000 / ((uint32_t)revsteps * (uint32_t)rpm);
    @brief  Release all pins of the stepper motor so it free-spins
void Adafruit_StepperMotor::release(void) {
  MC->setPin(AIN1pin, LOW);
  MC->setPin(AIN2pin, LOW);
  MC->setPin(BIN1pin, LOW);
  MC->setPin(BIN2pin, LOW);
  MC->setPWM(PWMApin, 0);
  MC->setPWM(PWMBpin, 0);
    @brief  Move the stepper motor with the given RPM speed, don't forget to call
    {@link Adafruit_StepperMotor.setSpeed} to set the speed!
    @param  steps The number of steps we want to move
    @param  dir The direction to go, can be FORWARD or BACKWARD
    @param  style How to perform each step, can be SINGLE, DOUBLE, INTERLEAVE or MICROSTEP
void Adafruit_StepperMotor::step(uint16_t steps, uint8_t dir,  uint8_t style) {
  uint32_t uspers = usperstep;
  uint8_t ret = 0;
  if (style == INTERLEAVE) {
    uspers /= 2;
 else if (style == MICROSTEP) {
    uspers /= MICROSTEPS;
    steps *= MICROSTEPS;
#ifdef MOTORDEBUG
    Serial.print("steps = "); Serial.println(steps, DEC);
#endif
  while (steps--) {
    //Serial.println("step!"); Serial.println(uspers);
    ret = onestep(dir, style);
    delayMicroseconds(uspers);
#ifdef ESP8266
    yield(); // required for ESP8266
#endif
    @brief  Move the stepper motor one step only, with no delays
    @returns The current step/microstep index, useful for {@link Adafruit_StepperMotor.step} to keep
    track of the current location, especially when microstepping
uint8_t Adafruit_StepperMotor::onestep(uint8_t dir, uint8_t style) {
  uint8_t a, b, c, d;
  uint8_t ocrb, ocra;
  ocra = ocrb = 255;
  // next determine what sort of stepping procedure we're up to
  if (style == SINGLE) {
    if ((currentstep/(MICROSTEPS/2)) % 2) { // we're at an odd step, weird
      if (dir == FORWARD) {
  currentstep += MICROSTEPS/2;
      else {
  currentstep -= MICROSTEPS/2;
    } else {           // go to the next even step
  currentstep += MICROSTEPS;
      else {
  currentstep -= MICROSTEPS;
  } else if (style == DOUBLE) {
    if (! (currentstep/(MICROSTEPS/2) % 2)) { // we're at an even step, weird
      } else {
    } else {           // go to the next odd step
      } else {
  } else if (style == INTERLEAVE) {
    } else {
      currentstep++;
    } else {
      // BACKWARDS
      currentstep--;
    currentstep += MICROSTEPS*4;
    currentstep %= MICROSTEPS*4;
    ocra = ocrb = 0;
    if ( (currentstep >= 0) && (currentstep < MICROSTEPS)) {
      ocra = microstepcurve[MICROSTEPS - currentstep];
      ocrb = microstepcurve[currentstep];
    } else if  ( (currentstep >= MICROSTEPS) && (currentstep < MICROSTEPS*2)) {
      ocra = microstepcurve[currentstep - MICROSTEPS];
      ocrb = microstepcurve[MICROSTEPS*2 - currentstep];
    } else if  ( (currentstep >= MICROSTEPS*2) && (currentstep < MICROSTEPS*3)) {
      ocra = microstepcurve[MICROSTEPS*3 - currentstep];
      ocrb = microstepcurve[currentstep - MICROSTEPS*2];
    } else if  ( (currentstep >= MICROSTEPS*3) && (currentstep < MICROSTEPS*4)) {
      ocra = microstepcurve[currentstep - MICROSTEPS*3];
      ocrb = microstepcurve[MICROSTEPS*4 - currentstep];
#ifdef MOTORDEBUG
  Serial.print("current step: "); Serial.println(currentstep, DEC);
  Serial.print(" pwmA = "); Serial.print(ocra, DEC);
  Serial.print(" pwmB = "); Serial.println(ocrb, DEC);
#endif
  MC->setPWM(PWMApin, ocra*16);
  MC->setPWM(PWMBpin, ocrb*16);
  // release all
 [u] uint8_t latch_state = 0; // all motor pins to 0
  //Serial.println(step, DEC);
    if ((currentstep >= 0) && (currentstep < MICROSTEPS))
      latch_state |= 0x03;
    if ((currentstep >= MICROSTEPS) && (currentstep < MICROSTEPS*2))
      latch_state |= 0x06;
    if ((currentstep >= MICROSTEPS*2) && (currentstep < MICROSTEPS*3))
      latch_state |= 0x0C;
    if ((currentstep >= MICROSTEPS*3) && (currentstep < MICROSTEPS*4))
      latch_state |= 0x09;
  } else {
    switch (currentstep/(MICROSTEPS/2)) {
    case 0:
      latch_state |= 0x1; // energize coil 1 only
      break;
    case 1:
      latch_state |= 0x3; // energize coil 1+2
      break;
    case 2:
      latch_state |= 0x2; // energize coil 2 only
      break;
    case 3:
      latch_state |= 0x6; // energize coil 2+3
      break;
    case 4:
      latch_state |= 0x4; // energize coil 3 only
      break;
    case 5:
      latch_state |= 0xC; // energize coil 3+4
      break;
    case 6:
      latch_state |= 0x8; // energize coil 4 only
      break;
    case 7:
      latch_state |= 0x9; // energize coil 1+4
      break;
#ifdef MOTORDEBUG
  Serial.print("Latch: 0x"); Serial.println(latch_state, HEX);
#endif
  if (latch_state & 0x1) {
   // Serial.println(AIN2pin);
    MC->setPin(AIN2pin, HIGH);
  } else {
  if (latch_state & 0x2) {
    MC->setPin(BIN1pin, HIGH);
   // Serial.println(BIN1pin);
  } else {
  if (latch_state & 0x4) {
    MC->setPin(AIN1pin, HIGH);
   // Serial.println(AIN1pin);
  } else {
  if (latch_state & 0x8) {
    MC->setPin(BIN2pin, HIGH);
   // Serial.println(BIN2pin);
  } else {
  return currentstep;[/u]
BRANDONRUF
by adafruit_support_bill on Tue Jul 03, 2018 9:54 am
I don't see where you added the quickstep code to the .cpp file. I'm surprised that your code even compiles.
by BRANDONRUF on Tue Jul 03, 2018 10:08 am
Ok I added the quickstep code to the end of the cpp file
 * @file Adafruit_MotorShield.cpp
 * @mainpage Adafruit FXOS8700 accel/mag sensor driver
 * @section intro_sec Introduction
 * This is the library for the Adafruit Motor Shield V2 for Arduino.
 * It supports DC motors & Stepper motors with microstepping as well
 * as stacking-support. It is *not* compatible with the V1 library!
 * For use with the Motor Shield https://www.adafruit.com/products/1483
 * and Motor FeatherWing https://www.adafruit.com/product/2927
 * This shield/wing uses I2C to communicate, 2 pins (SCL+SDA) are required
 * to interface.
 * Adafruit invests time and resources providing this open source code,
 * please support Adafruit and open-source hardware by purchasing
 * products from Adafruit!
 * @section author Author
 * Written by Limor Fried/Ladyada for Adafruit Industries.
 * @section license License
 * BSD license, all text here must be included in any redistribution.
#include <Wire.h>
#endif
  _addr = addr;
    @param    freq
    @param    theWire
    (on Due)
  if (! theWire) {
    _i2c = &Wire1;
#else
    _i2c = &Wire;
#endif
  } else {
    _i2c = theWire;
  // init PWM w/_freq
  _i2c->begin();
  _pwm.begin();
  _freq = freq;
  if (value > 4095) {
  } else
  if (value == LOW)
  else
  num--;
    // not init'd yet!
    if (num == 0) {
  num--;
    // not init'd yet!
    if (num == 0) {
               MOTORS
  MC = NULL;
  motornum = 0;
  switch (cmd) {
  case FORWARD:
    break;
  case BACKWARD:
    break;
  case RELEASE:
    break;
               STEPPERS
  uint8_t ret = 0;
    uspers /= 2;
#ifdef MOTORDEBUG
#endif
  while (steps--) {
#ifdef ESP8266
#endif
  uint8_t a, b, c, d;
  uint8_t ocrb, ocra;
  ocra = ocrb = 255;
      else {
      else {
      } else {
      } else {
    } else {
      currentstep++;
    } else {
      // BACKWARDS
      currentstep--;
    ocra = ocrb = 0;
#ifdef MOTORDEBUG
#endif
  // release all
  } else {
    case 0:
      break;
    case 1:
      break;
    case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    case 5:
      break;
    case 6:
      break;
    case 7:
      break;
#ifdef MOTORDEBUG
#endif
  } else {
  } else {
  } else {
  } else {
  return currentstep;
void loop()
    myMotor2->quickstep(FORWARD);
  Serial.println(millis() - start);
How do I find the serial output?
BRANDONRUF
by adafruit_support_bill on Tue Jul 03, 2018 10:11 am
There is an icon for the Serial Monitor in the upper right corner of the Arduino IDE.
by BRANDONRUF on Tue Jul 03, 2018 10:23 am
Serial output just says
Stepper test!
Double coil steps
As for coding did I modify it correctly?
BRANDONRUF
by adafruit_support_bill on Tue Jul 03, 2018 10:29 am
This line in your sketch will loop forever. So you will never get to the quickstep code.
  while(1){}
by BRANDONRUF on Tue Jul 03, 2018 10:38 am
It still runs at about the same speed
BRANDONRUF
by adafruit_support_bill on Tue Jul 03, 2018 10:45 am
You have delays in your code. That is in addition to the i2c and processing overhead and will slow the motor further.
