Arduino PowerBoost 500 shield faulty
by Darren20Chew on Sun Jul 08, 2018 10:40 pm
I received a faulty Arduino power boost 500 shield. It is not able to power up my Arduino Uno. I have tested that the battery and Arduino Uno is working fine, and so is my connection. I was rushing for my project and I bought another Powerboost Shield and it is not working. I would like to get a refund for both of my power boost shield. Thank you for your help.
Darren20Chew
Re: Arduino PowerBoost 500 shield faulty
by franklin97355 on Sun Jul 08, 2018 11:31 pm
Can you post some pictures of the soldering side so we can take a look? Have you tested the voltage output of the battery and the PowerBoost when it is not connected to the Arduino?
franklin97355
by Darren20Chew on Tue Jul 10, 2018 2:37 am
The soldering should be fine and I tested the battery and it is working fine as well.
Darren20Chew
by Darren20Chew on Tue Jul 10, 2018 2:40 am
However, when I connected the Power Boost shield to the battery and tested it out with my DMM. It appears when my DMM is connected to the output at 5v of the power boost board, there is no voltage. I tested this with both the board. So I think there is a fault with the board.
Darren20Chew
by adafruit2 on Fri Jul 13, 2018 11:48 am
what did you power it with? we test them before shipping...the blue LED should have lit when you plugged in the battery
adafruit2
Site Admin
by Darren20Chew on Fri Jul 13, 2018 12:04 pm
I have only powered the shield with the 3.7V battery. Nothing else.
Darren20Chew
by adafruit2 on Fri Jul 13, 2018 12:07 pm
ok - email support@adafruit for a refund - but whatever you're doing seems to be damaging them, so dont buy any more powerboosts!
adafruit2
Site Admin
by Darren20Chew on Fri Jul 13, 2018 12:12 pm
I have only used them to power Arduino Uno....
Darren20Chew
