Wave Shield
Re: Wave Shield
by laand on Mon Jul 30, 2018 6:13 pm
deleted and reinstalled WAV file. This is what I get
Wave test:
Free RSAM 648
Using partition 1, type is FAT32
Files found (*= fragmented}:
SYSTEM-1/
INDEXE-1DAT
3-18WA-1. WAV
subdir: SYSTEM-1/
Playing 3-18WA.WAV
But still no sound
laand
Re: Wave Shield
by adafruit_support_bill on Mon Jul 30, 2018 6:37 pm
Playing 3-18WA.WAV
According to that, it has found the file and is trying to play it. So the problem must be somewhere in the audio circuit.
If you have an ear-bud type headphone, connect a wire from the 'sleeve' to the GND pin. Then touch the 'tip' to either end of R7 while the file is playing. Do you hear anything?
Re: Wave Shield
by laand on Tue Jul 31, 2018 9:09 am
Yes I hear sound like of an ocean.
laand
Re: Wave Shield
by adafruit_support_bill on Tue Jul 31, 2018 9:38 am
Does it start and stop when the file is supposed to be playing, or is it constant?
Re: Wave Shield
by laand on Tue Jul 31, 2018 10:21 am
I put in the HELLOWOULD in and I beleave I'm hearing a HELLOWOULD but not plain. Before I had a song.
laand
Re: Wave Shield
by adafruit_support_bill on Tue Jul 31, 2018 10:52 am
But no sound coming from the speaker? Can you read the characters printed on the top of IC2 and IC3 and post them here?
Re: Wave Shield
by laand on Tue Jul 31, 2018 11:12 am
IC2 NCP 4921
E/P ej 8TC
1521
IC3 V6AA6 SN
TLV 2462 CP
laand
Re: Wave Shield
by adafruit_support_bill on Tue Jul 31, 2018 11:26 am
Those are the correct parts. So there are 2 issues:
1 - why is the output of the DAC noisy
2 - why is there no sound from the speaker.
Regarding issue #1: If you play the same file on your computer, does it sound OK?
Regarding issue #2. Using the same headphone with a wire connected to ground. Touch the tip to pin 1 of IC2 (the pin closest to the dot) and play the file again. Is the sound similar to what you heard on R7?
Re: Wave Shield
by laand on Tue Jul 31, 2018 12:10 pm
Sound on computer is very good, IC2 pin 1 is a buzz sound.
laand
Re: Wave Shield
by adafruit_support_bill on Tue Jul 31, 2018 12:11 pm
And still no sound at all from the speaker?
Re: Wave Shield
by laand on Tue Jul 31, 2018 12:24 pm
I am getting some sound out ofthe speaker, crackling. I think it tried to say Hellowould. Like there is a short.
laand
Re: Wave Shield
by laand on Tue Jul 31, 2018 12:29 pm
With the ear buds I do set HelloWould now.
laand
Re: Wave Shield
by adafruit_support_bill on Tue Jul 31, 2018 12:33 pm
OK. That is a good sign. I suspect that there is a marginal connection somewhere in the audio circuitry. Since the signal coming out of the DAC is noisy, we can start looking there.
Please post some photos that clearly show the soldering on the jumpers. Photos from about a 45 degree angle are best so we can clearly see the shape of the solder joint.
Re: Wave Shield
by laand on Tue Jul 31, 2018 6:33 pm
pic's
DSC_0742 (800x532).jpg (212.54 KiB) Viewed 119 times
laand
Re: Wave Shield
by laand on Tue Jul 31, 2018 6:34 pm
pic
DSC_0743 (800x532).jpg (219.76 KiB) Viewed 118 times
laand
