Data logger shield/timestamp
Re: Data logger shield/timestamp
by adafruit_support_bill on Fri Sep 14, 2018 6:44 pm
On earlier versions of the UNO, you need to short the SDA & SCL jumpers as described in the guide:
https://learn.adafruit.com/adafruit-dat ... inouts-4-6
by bps on Sat Sep 15, 2018 9:32 am
I'll do what you can I recommend. Will I be able to use this shield with an R3 if I decide to upgrade the UNO or will the shield be a pre-R3 only?
bps
by adafruit_support_bill on Sat Sep 15, 2018 9:38 am
It will work fine on an UNO R3 with the jumpers installed.
If using with a different kind of Arduino (Mega, Due, Zero, etc you may want to remove the jumpers.)
by bps on Sat Sep 15, 2018 12:51 pm
I shorted the jumpers but I still get the same response. Any other suggestions?
bps
by adafruit_support_bill on Sat Sep 15, 2018 1:36 pm
If you purchased the shield within the last 30 days, we can try replacing it. Please contact support@adafruit.com with your order info and a link to this thread.
by bbg07 on Mon Sep 17, 2018 4:50 pm
Hello!
I am looking to purchase a data logging shield for my Arduino 101. I was wondering if the data logging shield (Product ID: 1141) is compatible with an Arduino 101?
I saw a list of other Arduinos that were compatible, but the 101 was not listed so just want to double check. Thanks!
bbg07
by adafruit_support_bill on Mon Sep 17, 2018 5:39 pm
@bbg07 - the question is a bit off-topic for this thread. Please start a new thread. If you mention the data logger and Arduino 101 in the title, someone familiar with that processor is more likely to see it.
by bps on Wed Sep 19, 2018 4:26 pm
I received the replacement data logging shield today. I built it, checked the soldering, and installed a fresh battery. I even soldered the two I2C jumpers on the bottom of the shield. I uploaded the sketch to test the rtc. No output. None. What seems to be going on here? When the sketch uploads or when I press the reset button, the red ED next to the battery case flashes but then nothing.
bps
by adafruit_support_bill on Wed Sep 19, 2018 4:54 pm
Please post some photos of the front and back of the new shield.
by bps on Thu Sep 20, 2018 10:09 am
I attach a photo of the top and back. I retouched all of the solder joints. Still no output. BTW, I get correct output from a CardInfo sketch.
bps
by adafruit_support_bill on Thu Sep 20, 2018 10:22 am
Do you have another Arduino to test it with? There may be a problem with the i2c pins on the one you are using.
by bps on Thu Sep 20, 2018 1:20 pm
Tried it with a new (as in "not used very much") R3. Still nothing.
bps
by bps on Thu Sep 20, 2018 1:27 pm
Here's something that may be of interest. I added the line Serial.println("Hello"); to the pcf8523 sketch immediately after the Serial.begin() line. "Hello" printed out but nothing else did.
bps
by adafruit_support_bill on Thu Sep 20, 2018 1:33 pm
Remove the shield from the Arduino and use a multimeter to test for conductivity between SCL and A5 (yellow circles) and also between SDA and A4 (red circles) as shown below:
by bps on Thu Sep 20, 2018 1:59 pm
I'm not all that handy with a multimeter but assuming that I did this correctly, I got no reading. The multimeter that I used (which I bought from you guys) is a DT-9205B+. The red lead is in the mA jaack with the black in COM. The dial is set on the 20 on the lower right hand section of the dial. I also turned the meter on.
bps
