Good day all,
I made my own LCD shield for design reason.
I am using then Adafruit_MCP23017.h library. How do I map the rs or the en input from the LCD to an output from the MCP23017?
Read a button and switch a LED works.
But know I have the
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
line in my code. Here I have to replace the rs, en, d4, d5, d6, d7.
Regards
Andy
ADAFRUIT_MCP23017 library and LCD 16x2 Display
- arcomp
Re: ADAFRUIT_MCP23017 library and LCD 16x2 Display
The RGB LCD Shield uses the same chip to control a 16x2 lcd display.
You can find links to the schematic and library here: https://learn.adafruit.com/rgb-lcd-shield/downloads
- arcomp
Thanks for your quick reply,
the adafruit shield is using B7, B5, B4, B3, B2 B1 for RS,EN,D4,D5,D6,D7.
My shield is using B2, B3,B4,B5,B6,B7.
Is there anyway where you can define your own ports to drive the LCD?
Regards
Andy
Regards
Andy
- arcomp
I had a look at the .cpp file
Do I have to change this part in the .cpp file?
from
// the I/O expander pinout
_rs_pin = 15;
_rw_pin = 14;
_enable_pin = 13;
_data_pins[0] = 12; // really d4
_data_pins[1] = 11; // really d5
_data_pins[2] = 10; // really d6
_data_pins[3] = 9; // really d7
to
_rs_pin = 10;
_rw_pin = 14; //---->not used LCD pin connected to gnd
_enable_pin = 11;
_data_pins[1] = 13; // really d5
_data_pins[2] = 14; // really d6
_data_pins[3] = 15; // really d7
from
_rs_pin = 15;
_rw_pin = 14;
_enable_pin = 13;
to
_rs_pin = 10;
_enable_pin = 11;
If those are the pins you are using, that should do it.
- arcomp
Thanks a lot.
I'm busy trying this out.
Regards
Andy
Regards
Andy
- arcomp
Nope,
didnt work out.
didnt work out.
- arcomp
Lets take another way.
I used the ADAFRUIT_MCP23017 library.
Here I could program it in this way that I press a button, connected to MCP pin 5 and toggle an output MCP output Nr. 8.
So o far that works.
Now I just need to declare the MCP outputs to RS,EN,D4,D5,D6,D7.
Code
That works so far.
I just want to include the LCD.
Regards
Andy
Code
#include <Wire.h>
#include "Adafruit_MCP23017.h"
#include <LiquidCrystal.h>
Adafruit_MCP23017 mcp;
mcp.begin(); // use default address 0
mcp.pinMode(0, INPUT); // Button UP
mcp.pinMode(1, OUTPUT); // NC
mcp.pinMode(2, INPUT); // Button Right
mcp.pinMode(3, INPUT); // Button Left
mcp.pinMode(4, OUTPUT); // Buzzer
mcp.pinMode(5, INPUT); // Button Down
mcp.pinMode(6, OUTPUT); // NC
mcp.pinMode(7, OUTPUT); // NC
mcp.pinMode(8, OUTPUT); // Green LED
mcp.pinMode(9, OUTPUT); // Red LED
mcp.pinMode(10, OUTPUT); // LCD RS
mcp.pinMode(11, OUTPUT); // LCD EN
mcp.pinMode(12, OUTPUT); // LCD D4
mcp.pinMode(13, OUTPUT); // LCD D5
mcp.pinMode(14, OUTPUT); // LCD D6
mcp.pinMode(15, OUTPUT); // LCD D7
mcp.digitalWrite(8, mcp.digitalRead(5));
mcp.digitalWrite(4, mcp.digitalRead(0));
mcp.digitalWrite(9, mcp.digitalRead(3));
That works so far.
Regards
Andy
Last edited by adafruit_support_bill on Tue Sep 18, 2018 10:57 am, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums
You can't use the standard LiquidCrystal library - since it does not know how you communicate via the port expander.
The Adafruit_RGBLCDShield library shows how to do it.
- arcomp
Thanks for your reply,
I did change the adafruitRGBLCD_shield.cpp to my LCD pins.
_rs_pin = 10;
_rw_pin = 255;
_enable_pin = 11;
_button_pins[0] = 0;
_button_pins[1] = 2;
_button_pins[2] = 3;
_button_pins[3] = 5;
but still doesn't work.
Any suggestions??
Regards
Andy
_rs_pin = 10;
_rw_pin = 255;
_enable_pin = 11;
Any suggestions??
Regards
Andy
Double-check you pin assignments. This code was developed and tested to work with our shields, we can't realistically support custom hardware.
- arcomp
Good morning,
I do know and understand that you are only supporting your own products.
Just to finish up the post.
With the adafruit_mcp23017 library I can freely choose an input or an output. So far I did get it working by pressing a button and switch on a LED. But there is no possibility to drive the LCD with it.
With the adafruit_RGBLCDShield library there is a possibility to get the LCD working, I even could change my design from my own LCD shield, but in the .cpp file I couldnt see a possibility to address an output which I need for 2 LED and a buzzer.
What a pitty. Today I'm trying to do my best again.
Regards
Andy
Regards
Andy
- arcomp
Maybe another hint from you if I may ask?
I managed to display text with the adafruitRGBshield library by editing the .cpp file and declared my rs,en,d4,d5,d6,d7 to the right MCP23017 pins. at the same I declared my inputs and outputs.
How can I read a button ( your buttons pull to ground and my ones to Vcc ) and how to address an output.
Using your example brings "LEFT RIGHT DOWN..." on the display with a flickering and only when I push all 4 buttons the display is stable.
Regards
Andy
Regards
Andy
Use the digitalRead() and digitalWrite() functions in the Adafruit_MCP23017 library. They work the same way as the Arduino digitalRead and digitalWrite. If you look in the shield library, it is full of examples.How can I read a button ( your buttons pull to ground and my ones to Vcc ) and how to address an output.
- arcomp
Good morning,
unfortunately using both librarys at the same time doesnt work:
So either I have text on the LCD via the AdafruitRGBshield library or I have buttons and LED outputs via the Adafruit_MCP23017 library.
But working both together somehow doesn't work.
Regards
Andy
Example code for the Adafruit RGB Character LCD Shield and Library
This code displays text on the shield, and also reads the buttons on the keypad.
When a button is pressed, the backlight changes color.
// include the library code:
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
//Adafruit_MCP23017 mcp;
// Debugging output
Serial.begin(9600);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
//mcp.begin();
//mcp.pinMode(5, INPUT);
//mcp.pinMode(8, OUTPUT);
// Print a message to the LCD. We track how long it takes since
// this library has been optimized a bit and we're proud of it :)
int time = millis();
lcd.print("Hello, world!");
time = millis() - time;
Serial.print("Took "); Serial.print(time); Serial.println(" ms");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
//mcp.digitalWrite(8, mcp.digitalRead(5));
Regards
Andy
- LCD shield schematic.JPG (96.03 KiB) Viewed 294 times
Last edited by adafruit_support_bill on Fri Sep 21, 2018 5:42 am, edited 1 time in total.
