Motor Shield v2.3 problems after pulling power
- ben_cowden
Hi. I have two Adafruit Motor Shield v2.3's running on a Metro M0 Express, driving 3 steppers. Each stepper has a leadscrew and a carriage that moves up and down. During testing, one of the carriages was about to collide with the chassis so I pulled the 12v plug, and now things are malfunctioning. What keeps happening is that every time the code begins (when I open the serial monitor), the first motor just starts driving in a direction, not at all in the sketch. I can't figure out how to get it to stop other than pulling the power, which puts me back at square 1. I tried restarting the computer, disconnecting power, pushing reset buttons, loading a different sketch. The Metro board is working (new sketch loaded). But the steppers keep malfunctioning. Any advice? Thanks!
Re: Motor Shield v2.3 problems after pulling power
The shield has no processor of its own and cannot step motors by itself. If motors are stepping continuously, it is because your sketch is continuously sending it step commands.What keeps happening is that every time the code begins (when I open the serial monitor), the first motor just starts driving in a direction, not at all in the sketch.
Please post the code that you are using.
- ben_cowden
Thanks Bill. I actually think something bizarre is happening. I got things working again, but moved the problem stepper from one side of the shield to the other. I added tons of serial messages between each step so I could pinpoint where the error is happening. Things worked, but that one motor struggled under its load until *poof*, it ran smooth but just kept running, and I hit <reset> before it crashed. Now I have the same original problem: setup goes fine until this one moment when the motor just start turning and won't stop. Here's the code and a screenshot of where things go awry:
[img] [/img]
#include <Wire.h>
#include <Adafruit_MotorShield.h>
Adafruit_MotorShield AFMStop = Adafruit_MotorShield(0x61); //right jumpers soldered
Adafruit_MotorShield AFMSbot = Adafruit_MotorShield(0x60); //bottom board with stacking headers
Adafruit_StepperMotor *myMotor1 = AFMStop.getStepper(200, 1);
Adafruit_StepperMotor *myMotor2 = AFMStop.getStepper(200, 2);
Adafruit_StepperMotor *myMotor3 = AFMSbot.getStepper(200, 2);
#define limit1 8 //Pin8 connected to the limit switch activate for limit switch
#define limit2 9 //Pin9 connected to the limit switch activate for limit switch
#define fill 5 //Pin5 connected to button for filling bitters syringe
#define button 4 //Pin 4 connected to button
int buttonState = 0; //variable for reading the button
int spiid = 400; //speed of motor variable
int steps1; // Variable for pot1 reading
int steps2; // Variable for pot2 reading
int steps3; // Variable for pot3 reading
Serial.begin(9600); // initialize serial communication at 9600 bits per second
while (!Serial); //only begins after serial monitor is opened
Serial.println("Weeee! let's go!");
delay(100);
Serial.println("Begin talking to the bottom board");
AFMSbot.begin();
Serial.println("Begin talking to the top board");
AFMStop.begin();// create with the default frequency 1.6KHz
Serial.println("setting speed");
myMotor1->setSpeed(spiid);
myMotor2->setSpeed(spiid);
myMotor3->setSpeed(spiid);
Serial.println("Running Movement test");
for (int i=0; i<50; i++) {
myMotor1->onestep(FORWARD, SINGLE);
myMotor3->onestep(FORWARD, SINGLE);
delay(3);
myMotor1->onestep(BACKWARD, SINGLE);
myMotor3->onestep(BACKWARD, SINGLE);
delay(3);
Serial.println("starting homing procedure");
// Homing procedure at startup:
while (digitalRead(limit1) == LOW) { // Do this until the switch is activated
Serial.println("Homing");
myMotor3->step(1, BACKWARD, SINGLE);
while (digitalRead(limit1) == HIGH) { // Do this until the switch is not activated
myMotor3->step(1, FORWARD, SINGLE);
steps3=0; // Reset position variable to zero
while (digitalRead(limit2) == LOW) { // Do this until the switch is activated
myMotor1->step(1, BACKWARD, SINGLE);
while (digitalRead(limit2) == HIGH) { // Do this until the switch is not activated
myMotor1->step(1, FORWARD, SINGLE);
steps1=0; // Reset position variable to zero
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(button);
if (digitalRead(button) == HIGH) { //if the button is pressed
steps1 = map(analogRead(A0), 1, 1023, 50, 1200);
steps2 = map(analogRead(A1), 1, 1023, 30, 100);
steps3 = map(analogRead(A2), 1, 1023, 50, 1200);
Serial.print("Bourbon pot = ");
Serial.println(steps1);
Serial.print("Vermouth pot = ");
Serial.println(steps3);
Serial.print("Bitters pot = ");
Serial.println(steps2);
delay (1000);
pour();} //do the pour
else if (digitalRead(button) == LOW) {
Serial.println("waiting...");
while (digitalRead(fill) == HIGH) { //if the fill button is pressed
Serial.println("Filling Bitters!");
myMotor2->step(1, BACKWARD, DOUBLE);
myMotor2->release();
delay (50);
void pour()
Serial.println("pouring");
Serial.println("Bourbon GO!");
for (int i=0; i<steps1; i++) {
myMotor1->step(1, FORWARD, DOUBLE);
if (digitalRead(fill) == HIGH) { //if the fill button is pressed
bourbonHome();
myMotor1->step(1, BACKWARD, DOUBLE);
myMotor1->step(1, FORWARD, INTERLEAVE);
steps1=0; // Reset position variable to zero myMotor1->release();
Serial.println("Vermouth GO!");
for (int i=0; i<steps3; i++) {
myMotor3->step(1, FORWARD, DOUBLE);
vermouthHome();
myMotor3->step(1, BACKWARD, DOUBLE);
myMotor3->step(1, FORWARD, INTERLEAVE);
steps3=0; // Reset position variable to zero myMotor3->release();
Serial.println("Bitters GO!");
myMotor2->step(steps2, FORWARD, DOUBLE);
myMotor1->release(); //release the motors so they don't have to maintain position
delay (1000);
void bourbonHome()
void vermouthHome()
- ben_cowden
Thanks Bill! I shouldn't be surprised that you are absolutely correct. I am very grateful for your help. I inserted some checks on the button inputs, and lo and behold! I ended up swapping the input pin for one of the limit switches (I tested the button itself, but it works fine), and we are all systems GO for the moment! Thanks!
Good to hear you have got it going. Thanks for the follow-up.
